Oracle Solaris Trusted Extensions Administrator's Procedures
Trusted Extensions Audit Tokens
The audit tokens that Trusted Extensions software adds to the Solaris OS are listed alphabetically in the following table. The tokens are also listed in the audit.log(4) man page.
Table 18–2 Trusted Extensions Audit Tokens
Token Name
Description
label Token
Sensitivity label
xatom Token
X window atom identification
xclient Token
X client identification
xcolormap Token
X window color information
xcursor Token
X window cursor information
xfont Token
X window font information
xgc Token
X window graphical context information
xpixmap Token
Xwindow pixel mapping information
xproperty Token
X window property information
xselect Token
X window data information
xwindow Token
X window window information
label Token
The label token contains a sensitivity label. This token contains the following fields:
The following figure shows the token format.
Figure 18–2 label Token Format
The context describes the graphic.
A label token is displayed by the praudit command as follows:
sensitivity label,ADMIN_LOW
xatom Token
The xatom token contains information concerning an X atom. This token contains the following fields:
An xatom token is displayed by praudit as follows:
X atom,_DT_SAVE_MODE
xclient Token
The xclient token contains information concerning the X client. This token contains the following fields:
An xclient token is displayed by praudit as follows:
X client,15
xcolormap Token
The xcolormap token contains information about the colormaps. This token contains the following fields:
Figure 18–3 Format for xcolormap, xcursor, xfont, xgc, xpixmap, and xwindow Tokens
An xcolormap token is displayed by praudit as follows:
X color map,0x08c00005,srv
xcursor Token
The xcursor token contains information about the cursors. This token contains the following fields:
Figure 18–3 shows the token format.
An xcursor token is displayed by praudit as follows:
X cursor,0x0f400006,srv
xfont Token
The xfont token contains information about the fonts. This token contains the following fields:
An xfont token is displayed by praudit as follows:
X font,0x08c00001,srv
xgc Token
The xgc token contains information about the xgc. This token contains the following fields:
An xgc token is displayed by praudit as follows:
Xgraphic context,0x002f2ca0,srv
xpixmap Token
The xpixmap token contains information about the pixel mappings. This token contains the following fields:
An xpixmap token is displayed by praudit as follows:
X pixmap,0x08c00005,srv
xproperty Token
The xproperty token contains information about various properties of a window. This token contains the following fields:
The following figure shows an xproperty token format.
Figure 18–4 xproperty Token Format
An xproperty token is displayed by praudit as follows:
X property,0x000075d5,root,_MOTIF_DEFAULT_BINDINGS
xselect Token
The xselect token contains the data that is moved between windows. This data is a byte stream with no assumed internal structure and a property string. This token contains the following fields:
Figure 18–5 xselect Token Format
An xselect token is displayed by praudit as follows:
X selection,entryfield,halogen
xwindow Token
The xwindow token contains information about a window. This token contains the following fields:
An xwindow token is displayed by praudit as follows:
X window,0x07400001,srv
