Oracle Solaris Trusted Extensions Administrator's Procedures
Chapter 5 Administering Security Requirements in Trusted Extensions (Tasks)
This chapter contains tasks that are commonly performed on a system that is configured with Solaris Trusted Extensions.
Common Tasks in Trusted Extensions (Task Map)
The following task map describes procedures that set up a working environment for administrators of Trusted Extensions.
Task
Description
For Instructions
Change the editor program for the trusted editor.
Specify the editor for administrative files.
How to Assign the Editor of Your Choice as the Trusted Editor
Change the password for root.
Specify a new password for the root user, or for the root role.
How to Change the Password for root
Change the password for a role.
Specifies a new password for your current role.
Example 5–2
Use the Secure Attention key combination.
Gets control of the mouse or keyboard. Also, tests whether the mouse or keyboard is trusted.
How to Regain Control of the Desktop's Current Focus
Determine the hexadecimal number for a label.
Displays the internal representation for a text label.
How to Obtain the Hexadecimal Equivalent for a Label
Determine the text representation for a label.
Displays the text representation for a hexadecimal label.
How to Obtain a Readable Label From Its Hexadecimal Form
Edit system files.
Securely edits Solaris or Trusted Extensions system files.
How to Change Security Defaults in System Files
Allocate a device.
Uses a peripheral device to add information to or remove information from the system.
How to Allocate a Device in Trusted Extensions in Oracle Solaris Trusted Extensions User’s Guide
Administer a host remotely.
Administers Solaris or Trusted Extensions hosts from a remote host.
Chapter 8, Remote Administration in Trusted Extensions (Tasks)
ProcedureHow to Assign the Editor of Your Choice as the Trusted Editor
The trusted editor uses the value of the $EDITOR environment variable as its editor.
Before You Begin
You must be in a role in the global zone.
  1. Determine the value of the $EDITOR variable.
    # echo $EDITOR
    The following are editor possibilities. The $EDITOR variable might also not be set.
    • /usr/dt/bin/dtpad – Is the editor that CDE provides.
    • /usr/bin/gedit – Is the editor that Java Desktop System, Release number provides. Solaris Trusted Extensions (JDS) is the trusted version of that desktop.
    • /usr/bin/vi – Is the visual editor.
  2. Set the value of the $EDITOR variable.
    • To set the value permanently, modify the value in the shell initialization file for the role.
      For example, in the role's home directory, modify the .kshrc file for a Korn shell, and the .cshrc file for a C shell.
    • To set the value for the current shell, set the value in the terminal window.
      For example, in a Korn shell, use the following commands:
      # setenv EDITOR=pathname-of-editor
      # export $EDITOR
      In a C shell, use the following command:
      In a Bourne shell, use the following commands:
      # EDITOR=pathname-of-editor
      # export EDITOR
Example 5–1 Specifying the Editor for the Trusted Editor
The Security Administrator role wants to use vi when editing system files. A user who has assumed the role modifies the .kshrc initialization file in the role's home directory.
$ cd /home/secadmin
$ vi .kshrc
## Interactive shell
set -o vi
export EDITOR=vi
The next time that any user assumes the Security Administrator role, vi is the trusted editor.
ProcedureHow to Change the Password for root
The Security Administrator role is authorized to change any account's password at any time by using the Solaris Management Console. However, the Solaris Management Console cannot change the password of a system account. A system account is an account whose UID is below 100. root is a system account because its UID is 0.
  1. Become superuser.
    If your site has made superuser into the root role, assume the root role.
  2. Choose Change Password from the Trusted Path menu.
    • In Trusted JDS, click the trusted symbol in the trusted stripe.
      From the trusted path menu, choose Change Password.
      The illustration shows the trusted symbol and the Trusted
Path menu in Trusted JDS.
    • In Solaris Trusted Extensions (CDE), open the Trusted Path menu.
      1. Click mouse button 3 over the workspace switch area.
      The illustration shows the Trusted Path menu in Trusted
CDE.
  3. Change the password, and confirm the change.
Example 5–2 Changing the Password for a Role
Any user who can assume a role that is defined in LDAP can use the Trusted Path menu to change the password for the role. The password is then changed in LDAP for all users who attempt to assume the role.
As in the Solaris OS, the Primary Administrator role can change the password for a role by using the Solaris Management Console. In Trusted Extensions, the Security Administrator role can change another role's password by using the Solaris Management Console.
ProcedureHow to Regain Control of the Desktop's Current Focus
The “Secure Attention” key combination can be used to break a pointer grab or a keyboard grab by an untrusted application. The key combination can also be used to verify if a pointer or a keyboard has been grabbed by a trusted application. On a multiheaded system that has been spoofed to display more than one trusted stripe, this key combination warps the pointer to the authorized trusted stripe.
  1. To regain control of a Sun keyboard, use the following key combination.
    Press the keys simultaneously to regain control of the current desktop focus. On the Sun keyboard, the diamond is the Meta key.
    <Meta> <Stop>
    If the grab, such as a pointer, is not trusted, the pointer moves to the stripe. A trusted pointer does not move to the trusted stripe.
  2. If you are not using a Sun keyboard, use the following key combination.
    <Alt> <Break>
    Press the keys simultaneously to regain control of the current desktop focus on your laptop.
Example 5–3 Testing If the Password Prompt Can Be Trusted
On an x86 system that is using a Sun keyboard, the user has been prompted for a password. The cursor has been grabbed, and is in the password dialog box. To check that the prompt is trusted, the user presses the <Meta> <Stop> keys simultaneously. When the pointer remains in the dialog box, the user knows that the password prompt is trusted.
If the pointer had moved to the trusted stripe, the user would know that the password prompt could not be trusted, and contact the administrator.
Example 5–4 Forcing the Pointer to the Trusted Stripe
In this example, a user is not running any trusted processes but cannot see the mouse pointer. To bring the pointer to the center of the trusted stripe, the user presses the <Meta> <Stop> keys simultaneously.
ProcedureHow to Obtain the Hexadecimal Equivalent for a Label
This procedure provides an internal hexadecimal representation of a label. This representation is safe for storing in a public directory. For more information, see the atohexlabel(1M) man page.
Before You Begin
You must be in the Security Administrator role in the global zone. For details, see How to Enter the Global Zone in Trusted Extensions.
  1. To obtain a hexadecimal value for a label, do one of the following.
    • To obtain the hexadecimal value for a sensitivity label, pass the label to the command.
      $ atohexlabel "CONFIDENTIAL : NEED TO KNOW"
      0x0004-08-68
    • To obtain the hexadecimal value for a clearance, use the -c option.
      $ atohexlabel -c "CONFIDENTIAL NEED TO KNOW"
      0x0004-08-68
      Note –
      Human readable sensitivity labels and clearance labels are formed according to rules in the label_encodings file. Each type of label uses rules from a separate section of this file. When a sensitivity label and a clearance label both express the same underlying level of sensitivity, the labels have identical hexadecimal forms. However, the labels can have different human readable forms. System interfaces that accept human readable labels as input expect one type of label. If the text strings for the label types differ, these text strings cannot be used interchangeably.
      In the default label_encodings file, the text equivalent of a clearance label does not include a colon (:).
Example 5–5 Using the atohexlabel Command
When you pass a valid label in hexadecimal format, the command returns the argument.
$ atohexlabel 0x0004-08-68
0x0004-08-68
When you pass an administrative label, the command returns the argument.
$ atohexlabel admin_high
ADMIN_HIGH
atohexlabel admin_low
ADMIN_LOW
Troubleshooting
The error message atohexlabel parsing error found in <string> at position 0 indicates that the <string> argument that you passed to atohexlabel was not a valid label or clearance. Check your typing, and check that the label exists in your installed label_encodings file.
ProcedureHow to Obtain a Readable Label From Its Hexadecimal Form
This procedure provides a way to repair labels that are stored in internal databases. For more information, see the hextoalabel(1M) man page.
Before You Begin
  1. To obtain the text equivalent for an internal representation of a label, do one of the following.
    • To obtain the text equivalent for a sensitivity label, pass the hexadecimal form of the label.
      $ hextoalabel 0x0004-08-68
    • To obtain the text equivalent for a clearance, use the -c option.
      $ hextoalabel -c 0x0004-08-68
ProcedureHow to Change Security Defaults in System Files
In Trusted Extensions, the security administrator changes or accesses default security settings on a system.
Files in the /etc/security and /etc/default directories contain security settings. On a Solaris system, superuser can edit these files. For Solaris security information, see Chapter 3, Controlling Access to Systems (Tasks), in System Administration Guide: Security Services.
Caution – Caution –
Relax system security defaults only if site security policy allows you to.
Before You Begin
  1. Use the trusted editor to edit the system file.
    For details, see How to Edit Administrative Files in Trusted Extensions.
    The following table lists the security files and what security parameters to change in the files.
    File
    Task
    For More Information
    /etc/default/login
    Reduce the allowed number of password tries.
    See the example under How to Monitor All Failed Login Attempts in System Administration Guide: Security Services.
    passwd(1) man page
    /etc/default/kbd
    Disable keyboard shutdown.
    How to Disable a System’s Abort Sequence in System Administration Guide: Security Services
    Note –
    On hosts that are used by administrators for debugging, the default setting for KEYBOARD_ABORT allows access to the kadb kernel debugger. For more information about the debugger, see the kadb(1M) man page.
    /etc/security/policy.conf
    Require a more powerful algorithm for user passwords.
    Remove a basic privilege from all users of this host.
    Restrict users of this host to Basic Solaris User authorizations.
    policy.conf(4) man page
    /etc/default/passwd
    Require users to change passwords frequently.
    Require users to create maximally different passwords.
    Require a longer user password.
    Require a password that cannot be found in your dictionary.
    passwd(1) man page
