In Trusted Extensions, each label requires a separate home directory mount. The automount command has been modified to handle these labeled automounts. For each zone, the automounter, autofs, mounts an auto_home_zone-name file. For example, the following is the entry for the global zone in the auto_home_global file:
+auto_home_global * -fstype=lofs :/export/home/& |
When a zone that permits lower-level zones to be mounted is booted, the following occurs. The home directories of lower-level zones are mounted read only under /zone/<zone-name>/export/home. The auto_home_<zone-name> map specifies the /zone path as the source directory for an lofs remount onto /zone/<zone-name>/home/<username>.
For example, the following is an auto_home_public entry in an auto_home_zone-at-higher-label map that is generated from a higher-level zone:
+auto_home_public * -fstype=lofs :/zone/public/export/home/& |
The following is the corresponding entry in the public zone:
auto_home_public * -fstype=lofs :/export/home/& |
When a home directory is referenced and the name does not match any entries in the auto_home_<zone-name> map, the map tries to match this loopback mount specification. The software creates the home directory when the following two conditions are met:
The map finds the match of the loopback mount specification
The home directory name matches a valid user whose home directory does not yet exist in zone-name
For details on changes to the automounter, see the automount(1M) man page.
