Trusted Extensions extends the Directory Server's schema to accommodate the tnrhdb and tnrhtp databases. Trusted Extensions defines two new attributes, ipTnetNumber and ipTnetTemplateName, and two new object classes, ipTnetTemplate and ipTnetHost.
The attribute definitions are as follows:
ipTnetNumber ( 1.3.6.1.1.1.1.34 NAME 'ipTnetNumber' DESC 'Trusted network host or subnet address' EQUALITY caseExactIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE ) |
ipTnetTemplateName ( 1.3.6.1.1.1.1.35 NAME 'ipTnetTemplateName' DESC 'Trusted network template name' EQUALITY caseExactIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE ) |
The object class definitions are as follows:
ipTnetTemplate ( 1.3.6.1.1.1.2.18 NAME 'ipTnetTemplate' SUP top STRUCTURAL DESC 'Object class for Trusted network host templates' MUST ( ipTnetTemplateName ) MAY ( SolarisAttrKeyValue ) ) ipTnetHost ( 1.3.6.1.1.1.2.19 NAME 'ipTnetHost' SUP top AUXILIARY DESC 'Object class for Trusted network host/subnet address to template mapping' MUST ( ipTnetNumber $ ipTnetTemplateName ) ) |
The cipso template definition in LDAP is similar to the following:
ou=ipTnet,dc=example,dc=example1,dc=exampleco,dc=com objectClass=top objectClass=organizationalUnit ou=ipTnet ipTnetTemplateName=cipso,ou=ipTnet,dc=example,dc=example1,dc=exampleco,dc=com objectClass=top objectClass=ipTnetTemplate ipTnetTemplateName=cipso SolarisAttrKeyValue=host_type=cipso;doi=1;min_sl=ADMIN_LOW;max_sl=ADMIN_HIGH; ipTnetNumber=0.0.0.0,ou=ipTnet,dc=example,dc=example1,dc=exampleco,dc=com objectClass=top objectClass=ipTnetTemplate objectClass=ipTnetHost ipTnetNumber=0.0.0.0 ipTnetTemplateName=internal |
