Oracle Solaris Trusted Extensions Administrator's Procedures
ProcedureHow to Configure a Restricted Label Range for a Printer
The default printer label range is ADMIN_LOW to ADMIN_HIGH. This procedure narrows the label range for a printer that is controlled by a Trusted Extensions print server.
Before You Begin
You must be in the Security Administrator role in the global zone.
  1. Start the Device Allocation Manager.
    • Choose the Allocate Device option from the Trusted Path menu.
    • In Trusted CDE, launch the Device Allocation Manager action from the Tools subpanel on the Front Panel.
  2. Click the Device Administration button to display the Device Allocation: Administration dialog box.
  3. Type a name for the new printer.
    If the printer is attached to your system, find the name of the printer.
  4. Click the Configure button to display the Device Allocation: Configuration dialog box.
  5. Change the printer's label range.
    1. Click the Min Label button to change the minimum label.
      Choose a label from the label builder. For information about the label builder, see Label Builder in Trusted Extensions.
    2. Click the Max Label button to change the maximum label.
  6. Save the changes.
    1. Click OK in the Configuration dialog box.
    2. Click OK in the Administration dialog box.
  7. Close the Device Allocation Manager.
