Oracle Solaris Trusted Extensions Administrator's Procedures
Interoperability of Trusted Extensions With Trusted Solaris 8 Printing
Trusted Solaris 8 and Trusted Extensions systems that have compatible label_encodings files and that identify each other as using a CIPSO template can use each other for remote printing. The following table describes how to set up the systems to enable printing. By default, users cannot list or cancel print jobs on a remote print server of the other OS. Optionally, you can authorize users to do so.
Originating System
Print Server System
Action
Results
Trusted Extensions
Trusted Solaris 8
Configure printing – In the Trusted Extensions tnrhdb, assign a template with the appropriate label range to the Trusted Solaris 8 print server. The label could be CIPSO or unlabeled.
Trusted Solaris 8 printer can print jobs from a Trusted Extensions system within the printer's label range.
Trusted Extensions
Trusted Solaris 8
Authorize users – On the Trusted Extensions system, create a profile that adds the needed authorizations. Assign the profile to users.
Trusted Extensions users can list or cancel print jobs that they send to a Trusted Solaris 8 printer.
Users cannot view or remove jobs at a different label.
Trusted Solaris 8
Trusted Extensions
Configure printing – In the Trusted Solaris 8 tnrhdb, assign a template with the appropriate label range to the Trusted Extensions print server. The label could be CIPSO or unlabeled.
Trusted Extensions printer can print jobs from a Trusted Solaris 8 system within the printer's label range.
Trusted Solaris 8
Trusted Extensions
Authorize users – On the Trusted Solaris 8 system, create a profile that adds the needed authorizations. Assign the profile to users.
Trusted Solaris 8 users can list or cancel print jobs that they send to a Trusted Extensions printer.
