Oracle Solaris Trusted Extensions Administrator's Procedures
Managing Printing in Trusted Extensions (Task Map)
Trusted Extensions procedures for configuring printing are performed after completing Solaris printer setup. The following task map points to the major tasks that manage labeled printing.
Task
Description
For Instructions
Configure printers for labeled output.
Enables users to print to a Trusted Extensions printer. The print jobs are marked with labels.
Configuring Labeled Printing (Task Map)
Remove visible labels from printer output.
Enables users to print at a specific label to a Solaris printer. The print jobs are not marked with labels.
Or, prevents labels from printing on a Trusted Extensions printer.
Reducing Printing Restrictions in Trusted Extensions (Task Map)
