The following task map describes tasks to debug your network.
Task |
Description |
For Instructions |
Determine why two hosts cannot communicate. |
Checks that the interfaces on a single system are up. | |
Uses debugging tools when two hosts cannot communicate with each other. | ||
Determine why an LDAP client cannot reach the LDAP server. |
Troubleshoots the loss of connection between an LDAP server and a client. |
Use this procedure if your system does not communicate with other hosts as expected.
You must be in the global zone in a role that can check network settings. The Security Administrator role and the System Administrator role can check these settings.
Verify that the system's network interface is up.
The following output shows that the system has two network interfaces, hme0 and hme0:3. Neither interface is up.
# ifconfig -a ... hme0: flags=1000843<BROADCAST,RUNNING,MULTICAST,IPv4> mtu 1500 index 2 inet 192.168.0.11 netmask ffffff00 broadcast 192.168.0.255 hme0:3 flags=1000843<BROADCAST,RUNNING,MULTICAST,IPv4> mtu 1500 index 2 inet 192.168.0.12 netmask ffffff00 broadcast 192.168.0.255 |
If the interface is not up, bring it up and then verify that it is up.
The following output shows that both interfaces are up.
# ifconfig hme0 up # ifconfig -a ... hme0: flags=1000843<UP,BROADCAST,RUNNING,MULTICAST,... hme0:3 flags=1000843<UP,BROADCAST,RUNNING,MULTICAST,.. |
To debug two hosts that should be communicating but are not, you can use Trusted Extensions and Solaris debugging tools. For example, Solaris network debugging commands such as snoop and netstat are available. For details, see the snoop(1M) and netstat(1M) man pages. For commands that are specific to Trusted Extensions, see Table 2–4.
For problems with contacting labeled zones, see Managing Zones (Task Map).
For debugging NFS mounts, see How to Troubleshoot Mount Failures in Trusted Extensions.
For debugging LDAP communications, see How to Debug a Client Connection to the LDAP Server.
You must be in the global zone in a role that can check network settings. The Security Administrator role or the System Administrator role can check these settings.
To troubleshoot the tnd daemon, change the polling interval and collect debugging information.
The tnd service is running only if the ldap service running.
For details, see the tnd(1M) man page.
Check that the hosts that cannot communicate are using the same naming service.
On each host, check the nsswitch.conf file.
Check the values for the Trusted Extensions databases in the nsswitch.conf file.
For example, at a site that uses LDAP to administer the network, the entries are similar to the following:
# Trusted Extensions tnrhtp: files ldap tnrhdb: files ldap |
If the values are different, correct the nsswitch.conf file.
To modify these entries, the system administrator uses the Name Service Switch action. For details, see How to Start CDE Administrative Actions in Trusted Extensions. This action preserves the required DAC and MAC file permissions.
Check that the LDAP naming service is configured.
$ ldaplist -l |
Check that both hosts are in the LDAP naming service.
$ ldaplist -l hosts | grep hostname |
Check that each host is defined correctly.
Use the Solaris Management Console to verify the definitions.
In the Security Templates tool, check that each host is assigned to a security template that is compatible with the security template of the other host.
For an an unlabeled system, check that the default label assignment is correct.
In the Trusted Network Zones tool, check that the multilevel ports (MLPs) are correctly configured.
Use the command line to check that the network information in the kernel is current.
Check that the assignment in each host's kernel cache matches the assignment on the network, and on the other host.
To get security information for the source, destination, and gateway hosts in the transmission, use the tninfo command.
Display the IP address and the assigned security template for a given host.
$ tninfo -h hostname IP Address: IP-address Template: template-name |
Display a template definition.
$ tninfo -t template-name template: template-name host_type: one of CIPSO or UNLABELED doi: 1 min_sl: minimum-label hex: minimum-hex-label max_sl: maximum-label hex: maximum-hex-label |
Display the MLPs for a zone.
$ tninfo -m zone-name private: ports-that-are-specific-to-this-zone-only shared: ports-that-the-zone-shares-with-other-zones |
Fix any incorrect information.
To change or check network security information, use the Solaris Management Console tools. For details, see How to Open the Trusted Networking Tools
To update the kernel cache, restart the tnctl service on the host whose information is out of date. Allow some time for this process to complete. Then, refresh the tnd service. If the refresh fails, try restarting the tnd service. For details, see How to Synchronize the Kernel Cache With Trusted Network Databases.
Rebooting clears the kernel cache. At boot time, the cache is populated with database information. The nsswitch.conf file determines whether local databases or LDAP databases are used to populate the kernel.
Collect transmission information to help you in debugging.
Verify your routing configuration.
Use the get subcommand to the route command.
$ route get [ip] -secattr sl=label,doi=integer |
For details, see the route(1M) man page.
View the label information in packets.
Use the snoop -v command.
The -v option displays the details of packet headers, including label information. This command provides a lot of detail, so you might want to restrict the packets that the command examines. For details, see the snoop(1M) man page.
View the routing table entries and the security attributes on sockets.
Use the -R option with the netstat -a|-r command.
The -aR option displays extended security attributes for sockets. The -rR option displays routing table entries. For details, see the netstat(1M) man page.
Misconfiguration of the client entry on the LDAP server can prevent the client from communicating with the server. Similarly, misconfiguration of files on the client can prevent communication. Check the following entries and files when attempting to debug a client-server communication problem.
You must be in the Security Administrator role in the global zone on the LDAP client.
Check that the remote host template for the LDAP server and for the gateway to the LDAP server are correct.
# tninfo -h LDAP-server # route get LDAP-server # tninfo -h gateway-to-LDAP-server |
If a remote host template assignment is incorrect, assign the host to the correct template by using the Security Templates tool in the Solaris Management Console.
Check and correct the /etc/hosts file.
Your system, the interfaces for the labeled zones on your system, the gateway to the LDAP server, and the LDAP server must be listed in the file. You might have more entries.
Look for duplicate entries. Remove any entries that are labeled zones on other systems. For example, if Lserver is the name of your LDAP server, and LServer-zones is the shared interface for the labeled zones, remove LServer-zones from /etc/hosts.
If you are using DNS, check and correct the entries in the resolv.conf file.
# more resolv.conf search list of domains domain domain-name nameserver IP-address ... nameserver IP-address |
Check that the tnrhdb and tnrhtp entries in the nsswitch.conf file are accurate.
Check that the client is correctly configured on the server.
# ldaplist -l tnrhdb client-IP-address |
Check that the interfaces for your labeled zones are correctly configured on the LDAP server.
# ldaplist -l tnrhdb client-zone-IP-address |
Verify that you can ping the LDAP server from all currently running zones.
# ldapclient list ... NS_LDAP_SERVERS= LDAP-server-address # zlogin zone-name1 ping LDAP-server-address LDAP-server-address is alive # zlogin zone-name2 ping LDAP-server-address LDAP-server-address is alive ... |
Configure LDAP and reboot.
For the procedure, see Make the Global Zone an LDAP Client in Trusted Extensions in Oracle Solaris Trusted Extensions Configuration Guide.
In every labeled zone, re-establish the zone as a client of the LDAP server.
# zlogin zone-name1 # ldapclient init \ -a profileName=profileName \ -a domainName=domain \ -a proxyDN=proxyDN \ -a proxyPassword=password LDAP-Server-IP-Address # exit # zlogin zone-name2 ... |
Halt all zones, lock the file systems, and reboot.
If you are using Solaris ZFS, halt the zones and lock the file systems before rebooting. If you are not using ZFS, you can reboot without halting the zones and locking the file systems.
# zoneadm list # zoneadm -z zone-name halt # lockfs -fa # reboot |
