Oracle Solaris Trusted Extensions Administrator's Procedures
ProcedureHow to Configure Routes With Security Attributes
Before You Begin
You must be in the Security Administrator role in the global zone.
  1. Add every destination host and gateway that you are using to route packets over the trusted network.
    The addresses are added to the local /etc/hosts file, or to its equivalent on the LDAP server. Use the Computers and Networks tool in the Solaris Management Console. The Files scope modifies the /etc/hosts file. The LDAP scope modifies the entries on the LDAP server. For details, see How to Add Hosts to the System's Known Network.
  2. Assign each destination host, network, and gateway to a security template.
    The addresses are added to the local /etc/security/tsol/tnrhdb file, or to its equivalent on the LDAP server. Use the Security Templates tool in the Solaris Management Console. For details, see How to Assign a Security Template to a Host or a Group of Hosts.
  3. Set up the routes.
    In a terminal window, use the route add command to specify routes.
    The first entry sets up a default route. The entry specifies a gateway's address, 192.168.113.1, to use when no specific route is defined for either the host or the packet's destination.
    # route add default 192.168.113.1  -static
    For details, see the route(1M) man page.
  4. Set up one or more network entries.
    Use the -secattr flag to specify security attributes.
    In the following list of commands, the second line shows a network entry. The third line shows a network entry with a label range of PUBLIC to CONFIDENTIAL : INTERNAL USE ONLY.
    # route add default 192.168.113.36
    # route add -net 192.168.102.0 gateway-101
    # route add -net 192.168.101.0 gateway-102 \
    -secattr min_sl=“PUBLIC”,max_sl=”CONFIDENTIAL : INTERNAL USE ONLY”,doi=1
  5. Set up one or more host entries.
    The new fourth line shows a host entry for the single-label host, gateway-pub. gateway-pub has a label range of PUBLIC to PUBLIC.
    -secattr min_sl="PUBLIC",max_sl="CONFIDENTIAL : INTERNAL USE ONLY",doi=1
    # route add -host 192.168.101.3 gateway-pub \
    -secattr min_sl="PUBLIC",max_sl="PUBLIC",doi=1
Example 13–14 Adding a Route With a Label Range of CONFIDENTIAL : INTERNAL USE ONLY to CONFIDENTIAL : RESTRICTED
The following route command adds to the routing table the hosts at 192.168.115.0 with 192.168.118.39 as its gateway. The label range is from CONFIDENTIAL : INTERNAL USE ONLY to CONFIDENTIAL : RESTRICTED, and the DOI is 1.
$ route add -net 192.168.115.0 192.168.118.39 \
-secattr min_sl="CONFIDENTIAL : INTERNAL USE ONLY",max_sl="CONFIDENTIAL : RESTRICTED",doi=1
The result of the added hosts is shown with the netstat -rR command. In the following excerpt, the other routes are replaced by ellipses (...).
$ netstat -rRn
192.168.115.0        192.168.118.39        UG       0      0
        min_sl=CNF : INTERNAL USE ONLY,max_sl=CNF : RESTRICTED,DOI=1,CIPSO
