Organizations that use the same Domain of Interpretation (DOI) agree among themselves to interpret label information and other security attributes in the same way. When Trusted Extensions performs a label comparison, a check is made as to whether the DOI is equal.
A Trusted Extensions system enforces label policy on one DOI value. All zones on a Trusted Extensions system must operate at the same DOI. A Trusted Extensions system does not provide exception handling on packets that are received from a system that uses a different DOI.
If your site uses a DOI value that is different from the default value, you must add this value to the /etc/system file, and change the value in every security template. For the initial procedure, see Configure the Domain of Interpretation in Oracle Solaris Trusted Extensions Configuration Guide. To configure the DOI in every security template, see Example 13–1.
