Java Desktop System Release 3 Installation Guide
Updating an Existing System From CD
If the Configurator detects that Linux is installed on your system, you are presented with the following options:
If you want to upgrade an installed version of Linux, perform the following steps:
  1. Select Update an existing system
    This option preserves configuration settings from your existing system whenever possible.
  2. Select Create a backup if you want to make a backup of your existing system.
  3. Click Next.
  4. You are prompted to choose the type of upgrade you require.
  5. Follow the online instructions to complete the update of your existing system as described in Installing From CD.
