Java Desktop System Release 3 Installation Guide
Guidelines for Partitioning
The following table contains recommended guidelines for partitioning your disk:
Table 2–1 Guidelines for Partitioning
Partition
Size
Type
Notes
6 GB, 4 GB minimum
Primary
Install the entire Java Desktop System operating system onto a single partition. This method provides sufficient space for you to install a later releases of the Java Desktop System without the need to repartition the disk.
swap
Double the size of RAM 256 MB minimum
swap
You can increase or reduce the size of the swap partition as necessary.
