Java Desktop System Release 3 Troubleshooting Guide
2.12 Upgrade Issues
2.12.1 No Audio Output
Platform
  • Linux
Problem
Change Request Number: 6236276
Audio does not work correctly after you upgrade from Java Desktop System Release 2 to Java Desktop System Release 3 because the sound card is not configured correctly during the upgrade installation.
Solution
After you upgrade from Java Desktop System Release 2 to Java Desktop System Release 3, you must configure the sound card using YaST2. Perform the following steps:
  1. Choose Launch ->Preferences ->System Preferences ->Hardware ->Sound Card.
  2. Enter the root password when prompted.
  3. Configure your sound card appropriately.
2.12.2 Dependency Errors During Upgrade
Platform
  • Linux
Problem
Change Request Number: 6272964
The following sequence produces dependency errors with several rpms:
  1. Perform an upgrade installation from Java Desktop System Release 2 to Java Desktop System Release 3.
  2. Change the Installation Mode from New to Upgrade in the last Installation Settings screen.
Solution
  1. Abort the installation.
  2. Restart the installation.
  3. Select Upgrade Installation from the Initial Installation Settings screen.
