Java Desktop System Release 3 Troubleshooting Guide
2.9 Text Editor
2.9.1 Cannot Input Multibyte Characters
Platform
  • Solaris OS for SPARC systems
  • Solaris OS for x86 systems
Problem
Change Request Number: 4937266
When you enable the Auto Indent function in the gedit text editor, you cannot input multibyte characters correctly.
Solution
Disable the Auto Indent function. Perform the following steps:
  1. Choose Edit ->Preferences.
  2. In the Categories list, select Editor, then Auto Indent.
  3. Deselect the Enable auto indentation option.
