Java Desktop System Release 3 Troubleshooting Guide
3.2 Chinese Locales
3.2.1 Characters Print With a Box
Platform
  • Solaris OS for SPARC systems
  • Solaris OS for x86 systems
Problem
Change request number: 4977300
Affects the following locales:
  • Chinese locales
  • Korean locales
The postscript printer does not bundle Chinese or Korean fonts, consequently characters printed out from Mozilla are printed in a box. CUPS needs to convert the Mozilla postscript fonts before the file can be printed.
Solution
  1. Choose Launch -> Preferences -> Printers.
  2. Right-click the PostScript printer icon, then select the Properties menu.
  3. Open the Advanced tab.
  4. Set the Ghostscript pre-filtering to Convert to PS level 1.
3.2.2 YaST2 Main Window Is Not Localized
Platform
  • Linux
Problem
Change Request Number: 6234759
  • zh_HK
  • ko_KR
The main window of the YaST2 application is not localized in the zh_HK locale and partically localized in the ko_KR locale.
Solution
ChooseLaunch ->Preferences ->Wireless Network Configuration or Launch ->Preferences ->System Preferencesto run theYaST2 application.
