Java Desktop System Release 3 Troubleshooting Guide
3.1.2 Modifier Keys Do Not Function Correctly
  • Solaris OS for SPARC systems
  • Solaris OS for x86 systems
Change Request Number: 4996542
The Alt key and Shift key might not function as modifier keys when you use the Internet/Intranet input method.
You might not be able to make a selection in a text using the Shift+arrow key combination. Latin characters might be inserted instead.
Use a different input method, for example Default. To switch input methods, right-click on an object and select Input method.
