Java Desktop System Release 3 Troubleshooting Guide
Chapter 1 System Issues
This chapter describes known system-level issues with the Java Desktop System Release 3.
1.1 User Preferences Not Fully Compatible
Platform
  • Solaris OS for SPARC systems
  • Solaris OS for x86 systems
  • Linux
Problem
Preferences set up in your home account for an earlier version of the GNOME Desktop might not be fully compatible with the version of the GNOME Desktop on the Java Desktop System Release 3.
Solution
Reset your preferences. Perform the following steps:
  1. Log out of the Java Desktop System.
  2. Click on Session and choose Failsafe terminal
  3. Log in.
  4. In the failsafe terminal window, enter the following commands:
    gnome-cleanup
    exit
  5. Log in again. Your GNOME preferences are now resest.
1.2 Gimp Is Missing From the Graphics Menu
Platform
Problem
Change Request Number: 6209566
Gimp is not available in the Graphics menu.
Solution
Edit the file /usr/share/applications/gimp-2.0.desktop to ensure that the TryExec and Exec variables include the full path to the Gimp binary.
  1. Open a terminal window.
  2. Edit the following file: /usr/share/applications/gimp-2.0.desktop
  3. Change the Exec and TryExec lines to add the full path to the Gimp binary:
    TryExec=/usr/sfw/bin/gimp2.0
    Exec=/usr/sfw/bin/gimp-remote-2.0 %u
1.3 Application Dependencies
Platform
Problem
Change Request Number: 6208829
You might not be able to complete the online registration of StarOffice 7 if the application cannot find Mozilla on the system. StarOffice 7 must be able to locate the Email and Calendar application to successfully send documents.
Solution
Add the /usr/sfw/bin to your PATH.
  2. Enter the following command:
    export PATH=/usr/sfw/bin:$PATH
  3. Open StarOffice. Enter the following command to start StarOffice:
    soffice
  4. Complete the StarOffice registration procedure.
