Java Desktop System Release 3 Accessibility Guide
Chapter 5 Using the Assistive Technologies
The Java Desktop System contains the following applications to enable users with a physical disability to use the desktop:
The desktop applications and utilities in the Java Desktop System are also designed with accessibility and usability in mind. However, there are some exceptions where the default applications are not suitable for users with special needs. In these situations, you must change the default application to an application that is suitable for all users, as described in the following sections:
Note –
Before you can use the On-Screen Keyboard and Screen Reader and Magnifier on Solaris systems, you must follow the steps outlined in A.3 Enabling XKB on Solaris Systems of this guide.
5.1 On-Screen Keyboard
The On-Screen Keyboard application displays virtual keyboards on your desktop. You can use the standard mouse pointer or alternative pointing device to operate the virtual keyboards. On-Screen Keyboard displays the following types of keyboards:
To start On-Screen Keyboard, click Launch, then choose Applications -> Accessibility -> On-Screen Keyboard. For more information about the On-Screen Keyboard application, see the online Help for On-Screen Keyboard.
5.1.1 Maximizing Application Windows for On-Screen Keyboard Users
If you are an On-Screen Keyboard user, you cannot use any application in Full Screen mode because the application window obscures the On-Screen Keyboard display.
To resize the window for use with the On-Screen Keyboard application, perform the following steps:
  1. Do not enable the Full Screen mode in the application.
  2. Give focus to the application window.
  3. Press F10 to maximize the application.
5.2 Screen Reader and Magnifier
The Screen Reader and Magnifier application enables users with limited vision, or no vision, to use the Java Desktop System and associated applications. Screen Reader and Magnifier provides the following functionality:
To start Screen Reader and Magnifier, click Launch, then choose Applications -> Accessibility -> Screen Reader and Magnifier. For more information about the application, see the online Help for Screen Reader and Magnifier.
5.3 Disabling the Screensaver
Before you use On-Screen Keyboard or Screen Reader and Magnifier, you must disable the screensaver. To disable the screensaver, perform the following steps:
  1. Click Launch, then choose Preferences -> Desktop Preferences -> Display -> Screensaver.
  2. In the Display Modes tabbed section, deselect the Lock Screen After check box.
  3. In the Mode drop-down list, select Disable Screen Saver.
  4. Choose File -> Restart Daemon.
  5. Choose File -> Quit to close the Screensaver Preferences dialog.
5.4 Displaying Online Help
The default online Help application for the Java Desktop System might not be suitable for some accessibility users. To change the default Help application for the Java Desktop System to an alternative Help application, perform the following steps:
  1. Click Launch, then choose Preferences -> Desktop Preferences -> File Associations.
  2. Click on the arrow next to Internet Services.
  3. Select the Gnome documentation entry.
  4. Click Edit.
  5. Replace the contents of the Program field with the following command:
    gnome-help "%s"
  6. Click OK.
  7. Click Close.
5.5 Displaying PDF Documents
The default Portable Document Format (PDF) viewer application for the Java Desktop System might not be suitable for some accessibility users. To change the default PDF viewer application for the Java Desktop System to another PDF viewer application, which might provide a slight improvement for accessibility users, perform the following steps:
  2. Click on the arrow next to Documents.
  3. Click on the arrow next to Published Materials.
  4. Select the PDF document entry.
  5. Click Edit.
  6. Enter the following command in the Program to run field:
    /usr/bin/gpdf
  7. Click OK.
  8. Click Close.
