Java Desktop System Email and Calendar User Guide
Spell Checking Preferences
Use the Spell Checking tabbed section to set spellchecker preferences. Table 12–10 lists the spellchecker preferences that you can set.
Table 12–10 Spellcheck Preferences
Dialog Element
Description
Language table
Displays a list of languages for which you have a dictionary installed.
To enable a language, select the language in the language table, then click on the Enable button. Alternatively, click on the check box in the Enabled column for the language to display a check mark in the check box.
Check spelling while I type
Select this option if you want Email and Calendar to check your spelling while you type. Email and Calendar checks your spelling against the dictionaries for the languages selected in the languages table.
Color for misspelled words
If you select the Check spelling while I type option, Email and Calendar underlines words in your messages that do not match terms in the dictionaries for the languages selected in the languages table.
Click on the color selector button to change the color of the line under words that do not match. Use the Pick a color dialog to select the color that you require.
