Java Desktop System Email and Calendar User Guide
Selecting Functionality to Configure
To select the functionality that you want to configure, perform the following steps:
  1. Choose Tools -> Settings.
  2. Select the functionality that you want to configure from the left pane of the Settings dialog. The preferences for that functionality are displayed in the right pane.
Use the right pane to modify the preferences for the functionality.
The Settings dialog contains buttons. The following table describes the buttons:
Button
Description
Apply
Click on this button to save any changes that you have made in the Settings dialog, and to implement the changes immediately.
Close
Click on this button to close the Settings dialog. Any changes that you made are not saved.
OK
Click on this button to save any changes that you have made in the Settings dialog, and to close the dialog.
