Java Desktop System Email and Calendar User Guide
To Forward Contacts
To send a contact or contact list as a file attachment in Vcard format, perform the following steps:
  1. In a contacts folder, select the contact or contact list that you want to send, then choose Actions -> Forward Contact.
    Alternatively, select the contact or contact list, then right-click on the contact or contact list. Choose Forward Contact from the popup menu.
    A message window is displayed, with the contact or contact list added as an attachment.
  2. Enter the email address to which you want to send the contact or contact list in the To field.
  3. Type any text that you want to add to the message in the content area, then choose File -> Send from the message window.
