Java Desktop System Email and Calendar User Guide
To Move Contacts
To move a contact or contact list to another folder, perform the following steps:
  1. In a contacts folder, select the contact or contact list that you want to move, then choose Actions -> Move to Folder.
    Alternatively, select the contact or contact list, then right-click on the contact or contact list. Choose Move to folder from the popup menu.
  2. Use the Move card to dialog to specify the folder to which you want to move the contact or contact list.
Note –
You can only move a contact or contact list to folders whose folder type is Contacts.
