To display one of the component applications in Email and
Calendar
, perform one of the following actions:
Click on the appropriate shortcut in the shortcuts bar. For example, click on the Calendar shortcut to display your calendar.
To display the shortcuts bar, choose View -> Shortcut Bar.
Choose a folder for the application from the folder pane. For example, choose an email folder such as Inbox to display the messages in the folder.
To display the folder pane, choose View -> Folder Bar.
Choose File -> Go to Folder. Select the folder for the application from the Go to folder dialog, then click OK. Alternatively, double-click on the folder.
