Java Desktop System Email and Calendar User Guide
Chapter 9 Using Sun Java System Calendar Server Accounts and Folders
The information in this chapter describes how to use Sun Java System Calendar Server for Email and Calendar accounts and folders.
Introduction to Sun Java System Calendar Server
The Java System Calendar Server connector enables you to use Email and Calendar as a client for the Java System Calendar Server. You can access one or more accounts on Calendar Server, send and receive invitations to meetings, and share calendar access with other people in your organization. The server is designed to work with LDAP directory servers and POP or IMAP email servers, which you can configure separately.
Calendar Server accounts are distinct from email or directory server accounts, and have their own section in the Settings dialog. Calendar Server accounts and folders differ from other Email and Calendar folders in the following ways:
Working with Calendar Server Accounts
This section describes how to create, edit, or delete a Calendar Server account.
To Create a Calendar Server Account
For information about how to create a new Calendar Server account, see To Add a Java System Calendar Server Account.
To Edit a Calendar Server Account
Perform the following steps:
  1. Choose Tools -> Settings to display the Settings dialog.
  2. Click on Sun Java System Accounts in the left pane. Email and Calendar displays a table of accounts that you have created, in the right pane.
  3. Select the account that you want to edit.
  4. Click Edit to display an Options for account name dialog. For information about the contents of the Options for account name dialog, see To Add a Java System Calendar Server Account.
  5. Use the Options for account name dialog to modify the details of the Calendar Server account.
  6. Click OK to save your changes and close the Options for account name dialog.
  7. Click OK to close the Information alert that tells you that you must restart Email and Calendar for the change to take effect.
  8. Restart Email and Calendar.
To Delete a Calendar Server Account
  2. Click on the Sun Java System Accounts button in the left pane. Email and Calendar displays a table of accounts that you have created, in the right pane.
  3. Select the account that you want to delete.
  4. Click Remove to display a confirmation alert.
  5. Click Delete to delete the selected account.
  6. Click OK to close the Information alert that tells you that you must restart Email and Calendar for the change to take effect.
  7. Restart Email and Calendar.
Using the Personal Calendar Folder
A calendar that is stored on a Java System Calendar Server functions in a similar way to a calendar stored locally, as described in Chapter 6, Using Calendar. There are some differences, as described in this section:
Free or Busy Information and the Directory Server
You can publish the free or busy information for an account, so that other users on the network can consult the schedule for that account when they want to organize a meeting.
To take advantage of free or busy information, and other Calendar Server features, use the Sun Java System Directory Server where possible. Alternatively, copy cards from the directory server to your local address book. Contact cards that come from the server have a special attribute that identifies that they have calendars on a Calendar Server. Cards that you create might appear identical to cards from the server. However, cards that you create function by email address only, and are not identified and integrated into the Calendar Server system.
Using the Personal Tasks Folder
Task folders stored on a Calendar Server server appear identical to those stored locally, as described in Chapter 7, Using Tasks.
Using the Personal Invitations Folder
When someone else creates a meeting in their Calendar Server calendar and lists you as a participant, a new invitation appears in your Personal Invitations folder. Invitation folders are structured as follows: the top half of the folder displays a list of invitations, and the bottom half of the folder displays details about the selected item.
The invitations are listed in table format. The following table describes the columns in the invitations table:
Column
Description
Starts
Indicates when the meeting is scheduled to start.
Summary
Provides a short description of the meeting.
Organizer
Specifies the organizer of the meeting.
Status
Indicates the current status of the meeting invitation. If the invitation is new, the status is Needs Action. To respond to the invitation, click on the field under the Status column header, to activate a drop-down list. Select one of the following status values from the drop-down list:
  • Accepted
  • Declined
  • Tentative
This status is displayed until the server synchronizes, which can take up to one minute. At that point, the invitation disappears from your Personal Invitations folder. If you accept the invitation, the event appears in your calendar.
For information about how to change the current view, save the current view, or create custom views, see Using Views.
Managing Subscriptions
If you have the required access permissions, you can subscribe to calendars owned by other users. If you do not have permission to read a calendar, you can see that the calendar exists and subscribe to the calendar, but you cannot read any of the calendar contents.
To Display All Calendars
To display all calendar folders on the Calendar Server, including folders that belong to other people, right-click on any Calendar Server folder. Choose Manage Subscriptions from the popup menu to open the Remote Calendar Subscriptions dialog.
The available calendars are listed in table format. The following table describes the columns in the calendars table:
Column
Description
Subscribed
Indicates whether you are subscribed to the calendar.
Calendar ID
Provides a unique identifier for the calendar.
Owner
Specifies the owner of the calendar.
Description
Provides a short description of the calendar.
Click Cancel to close the Remote Calendar Subscriptions dialog.
To Display a Subset of Calendars
By default, all calendars are listed. To display a subset of calendars, perform the following steps:
  1. Right-click on any Calendar Server folder, then choose Manage Subscriptions from the popup menu to open the Remote Calendar Subscriptions dialog.
  2. Select one of the following search criteria from the drop-down list:
    • Any field contains
    • Calendar ID contains
    • Owner contains
    • Description contains
  3. Type the search text in the text box.
  4. Click on the Find Now button. Email and Calendar lists only the calendars that match the search criteria.
    To clear the search, click on the Clear button.
  5. Click Cancel to close the Remote Calendar Subscriptions dialog.
To Subscribe to a Calendar
  2. Select the calendar to which you want to subscribe.
  3. Click on the Subscribe button.
  4. Click OK to save your changes and close the Remote Calendar Subscriptions dialog.
    Email and Calendar displays the selected calendar as a subfolder of the specified Calendar Server folder.
To Unsubscribe From a Calendar
  1. Right-click on any Calendar Server folder, then choose Manage Subscriptions from the popup menu to open the Remote Calendar Subscriptions window.
  2. Select the calendar from which you want to unsubscribe.
  3. Click on the Unsubscribe button.
    Email and Calendar deletes the selected calendar from the specified Calendar Server folder.
Setting Access Permissions for Folders
Access permissions control who can view or change each calendar folder.
Primary calendar owners have full access to their own calendars. The Calendar Server does not perform any access control checks when primary owners access their own calendars. Primary calendar owners can designate other owners for their calendars. The other owner can then act on behalf of the primary owner to schedule, delete, modify, accept, or decline events or tasks for a calendar.
Access Control Rule Ordering
The order in which the access control rules are listed is significant, because the server follows the first rule that grants or denies access, and ignores all subsequent conflicts.
Always put the most specific rules first, and the more general rules later. For example, suppose the first rule for the calendar jane.ashe:sports grants read access to all users. Then, the Calendar Server encounters a second rule that denies angela.liu read access to this calendar. In this case, the Calendar Server grants angela.liu read access to this calendar and ignores the second rule because of the conflict.
To ensure that an access right for a specific user such as angela.liu is honored, place the rule for angela.liu before more global entries such as a rule that applies to all users of a calendar.
To Display Access Permissions for a Folder
  1. Right-click on the folder, then choose Permissions from the popup menu to display the Folder permissions dialog.
  2. The access control rules are listed in the Permissions tabbed section. The following table describes the elements in the Permissions tabbed section:
    Element
    Description
    Name
    Name of the person or group with access permissions.
    Availability
    Select this option to allow the named person to see that the folder exists.
    Invite
    Select this option to allow the named person to invite you to meetings.
    Read
    Select this option to allow the named person to read the contents of the folder.
    Delete
    Select this option to allow the named person to delete the contents of the folder.
    Modify
    Select this option to allow the named person to modify the contents of the folder.
    Add
    Click Add to add a new entry to the permissions list.
    Edit
    Click Edit to edit an entry in the permissions list.
    Remove
    Click Remove to remove an entry from the permissions list.
    OK
    Click OK to save your changes and close the Folder permissions dialog.
    Cancel
    Click Cancel to close the Folder permissions dialog without saving your changes.
  3. To display the list of owners for the folder, click on the Owners tab. The following table describes the elements in the Owners tabbed section:
    Element
    Description
    User
    Displays the list of owners of the folder.
    Add
    Click Add to add a user to the User list.
    Remove
    Click Remove to remove the selected user from the User list.
    OK
    Cancel
To Grant Access Permissions to a User
  1. Right-click on the folder and choose Permissions from the popup menu to display the Folder permissions dialog.
  2. Click Add to display the Add permission dialog.
  3. Type the name of the user in the User text box.
  4. Select some or all of the required permissions:
    • Availability
    • Invite
    • Read
    • Delete
    • Modify
  5. Click OK to save your changes and close the Add permission dialog.
  6. Click OK to save your changes and close the Folder permissions dialog.
To Add a User to the List of Owners
  2. Click on the Owners tab to display the Owners tabbed section.
  3. Click Add to display the Add owner dialog.
  4. Type the name of the user in the Enter user name text box.
  5. Click OK to save your changes and close the Add owner dialog.
You can grant different levels of access to the owners. Unless you choose otherwise, the owners can view and edit Public, Private, and Confidential tasks and events for that folder.
To Remove Access Permissions from a User
  2. Select the user in the Permissions tabbed section.
  3. Deselect some or all of the required permissions:
    • Availability
    • Invite
    • Read
    • Delete
    • Modify
    Alternatively, click Remove to remove the user from the list.
  4. Click OK to save your changes and close the Folder permissions dialog.
To Remove a User from the List of Owners
  3. Select the user in the list.
  4. Click Remove to remove the user from the list of owners.
  5. Click OK to save your changes and close the Folder permissions dialog.
