Java Desktop System Email and Calendar User Guide
To Display All Calendars
To display all calendar folders on the Calendar Server, including folders that belong to other people, right-click on any Calendar Server folder. Choose Manage Subscriptions from the popup menu to open the Remote Calendar Subscriptions dialog.
The available calendars are listed in table format. The following table describes the columns in the calendars table:
Indicates whether you are subscribed to the calendar.
Calendar ID
Provides a unique identifier for the calendar.
Specifies the owner of the calendar.
Provides a short description of the calendar.
For information about how to change the current view, save the current view, or create custom views, see Using Views.
Click Cancel to close the Remote Calendar Subscriptions dialog.
