Java Desktop System Release 3 Accessibility Release Notes
3.11 Pointer Highlighting Feature Freezes the Desktop
Platform
Solaris
Problem
Change Request Number: 6291127
If you enable the Highlight the pointer when you press Ctrl option in the Mouse preference tool and you use the Ctrl key to copy and paste files, the desktop freezes.
Solution
Perform the following steps:
  1. Click Launch, then choose Preferences -> Desktop Preferences -> Mouse.
  2. Click on the Cursors tab in the Mouse Preferences dialog.
  3. Deselect the Highlight the pointer when you press Ctrl option.
