You can configure the following information with the display keyword:
Graphics card
Screen size
Color depth
Display resolution
Use the following syntax with the display keyword:
display=graphics_card {size=screen_size depth=color_depth resolution=screen_resolution} |
To set the appropriate values for the display keyword, run the kdmconfig -d command on the system you want to install. Copy the line of output that includes the display keyword, and include this line in the sysidcfg file.
