Solaris 10 6/06 Installation Guide: Basic Installations
Chapter 1 Planning for a Solaris Installation From CD or DVD Media (Tasks)
This chapter provides you with system requirements and planning information to help you install the Solaris OS. This chapter describes the following topics.
Note –
This book uses the term slice, but some Solaris documentation and programs might refer to a slice as a partition. To avoid confusion, this book distinguishes between fdisk partitions (which are supported only in Solaris for x86 based systems) and the divisions within the Solaris fdisk partition, which might be called slices or partitions.
System Requirements and Recommendations
The following tables list basic system requirements to install the Solaris OS.
Table 1–1 SPARC: Memory, Swap, and Processor Recommendations
SPARC Based System
Size
Memory to install or upgrade
256 MB is the recommended size. 128 MB is the minimum size.
Note –
Some optional installation features are enabled only when sufficient memory is present. For example, if you install from a DVD with insufficient memory, you install through the Solaris installation program's text installer, not through the GUI. For more information about these memory requirements, see Table 1–3.
Swap area
512 MB is the default size.
Note –
You might need to customize the swap space. Swap space is based on the size of the system's hard disk.
Processor requirements
200–MHz or faster processor is required.
Table 1–2 x86: Memory, Swap, and Processor Recommendations
x86 Based System
Size
512 MB is the recommended size. 256 MB is the minimum size.
Note –
Swap area
Note –
120–MHz or faster processor is recommended. Hardware floating-point support is required.
Solaris Installation Program GUI or Text Installer Requirements
The Solaris installation program on the Solaris 10 Operating System DVD or Solaris 10 Software - 1 CD can be run with a graphical user interface (GUI) or as an interactive text installer in a desktop or console session. For x86 based systems, the Solaris Device Configuration Assistant is included in the Solaris installation program.
You can choose to install the software with a GUI or with or without a windowing environment. If there is sufficient memory, the GUI is displayed by default. Other environments are displayed by default if memory is insufficient for the GUI. You can override defaults with the nowin or text boot options. But, you are limited by the amount of memory in your system or by installing remotely. Also if the Solaris installation program does not detect a video adapter, it automatically displays in a console-based environment. Table 1–3 and Table 1–4 describe these environments and list memory requirements for displaying them.
Table 1–3 SPARC: Memory Requirements for Display Options
SPARC: Memory
Type of Installation
Description
128–383 MB
Text-based
Contains no graphics, but provides a window and the ability to open other windows.
If you install by using the text boot option and the system has enough memory, you are installing in a windowing environment. If you are installing remotely through a tip line or using the nowin boot option, you are limited to the console-based installation.
384 MB or greater
GUI-based
Provides windows, pull-down menus, buttons, scrollbars, and iconic images.
Table 1–4 x86: Memory Requirements for Display Options
x86: Memory
Description
256–511 MB
Text-based
512 MB
GUI-based
You can also specify the installer you want to use during the installation by entering a selection or special command at a prompt. For instructions, see the procedures in Chapter 2, Installing With the Solaris Installation Program (Tasks).
General Disk Space Planning and Recommendations
Planning disk space is different for everyone. Consider allocating space for the following conditions, depending on your needs.
Table 1–5 General Disk Space and Swap Space Planning
Conditions for Space Allocations
Description
File systems
For each file system that you create, allocate an additional 30 percent more disk space than you need to enable you to upgrade to future Solaris versions.
By default, the Solaris installation methods create only root (/) and /swap. When space is allocated for OS services, the /export directory is also created. If you are upgrading to a major Solaris release, you might need to reslice your system or allocate double the space that you need at installation time. If you are upgrading to an update, you could prevent having to reslice your system by allocating extra disk space for future upgrades. A Solaris update release needs approximately 10 percent more disk space than the previous release. You can allocate an additional 30 percent of disk space for each file system to allow space for several Solaris updates.
The /var file system
If you intend to use the crash dump feature savecore(1M), allocate double the amount of your physical memory in the /var file system.
Swap
The Solaris installation program allocates a default swap area of 512 Mbytes under the following conditions:
  • If you use the installation program's automatic layout of disk slices
  • If you avoid manually changing the size of the swap slice
By default, the Solaris installation programs allocate swap space by placing swap so that it starts at the first available disk cylinder (typically cylinder 0 on SPARC based systems). This placement provides maximum space for the root (/) file system during the default disk layout and enables the growth of the root (/) file system during an upgrade.
If you think you might need to expand the swap area in the future, you can place the swap slice so that it starts at another disk cylinder by using one of the following methods.
For an overview of the swap space, see Chapter 21, Configuring Additional Swap Space (Tasks), in System Administration Guide: Devices and File Systems.
A server that is providing home directory file systems
By default, home directories are usually located in the /export file system.
The Solaris software group you are installing
A software group is a grouping of software packages. When you are planning disk space, remember that you can add or remove individual software packages from the software group that you select. For information about software groups, see Disk Space Recommendations for Software Groups.
Upgrade
Language support
For example, Chinese, Japanese, or Korean. If you plan to install a single language, allocate approximately 0.7 Gbytes of additional disk space for the language. If you plan to install all language supports, you need to allocate up to approximately 2.5 Gbytes of additional disk space for the language supports, depending on the software group you install.
Printing or mail support
Allocate additional space.
Additional software or third-party software
The Solaris software groups are collections of Solaris packages. Each software group includes support for different functions and hardware drivers.
When you are installing the Solaris software, you can choose to add or remove packages from the Solaris software group that you selected. When you are selecting which packages to add or remove, you need to know about software dependencies and how the Solaris software is packaged.
The following figure shows the grouping of software packages. Reduced Network Support contains the minimal number of packages and Entire Solaris Software Group Plus OEM Support contains all the packages.
Figure 1–1 Solaris Software Groups
The context describes the illustration.
Table 1–6 lists the Solaris software groups and the recommended amount of disk space that you need to install each group.
Note –
The disk space recommendations in Table 1–6 include space for the following items.
You might find that the software groups require less disk space than the amount that is listed in this table.
For additional information about how to plan your disk space, see Allocating Disk and Swap Space in Solaris 10 6/06 Installation Guide: Network-Based Installations.
Table 1–6 Disk Space Recommendations for Software Groups
Software Group
Description
Recommended Disk Space
Contains the packages for the Entire Solaris Software Group plus additional hardware drivers, including drivers for hardware that is not on the system at the time of installation.
6.8 Gbytes
Contains the packages for the Developer Solaris Software Group and additional software that is needed for servers.
6.7 Gbytes
Contains the packages for the End User Solaris Software Group plus additional support for software development. The additional software development support includes libraries, include files, man pages, and programming tools. Compilers are not included.
6.6 Gbytes
Contains the packages that provide the minimum code that is required to boot and run a networked Solaris system and the Common Desktop Environment.
5.3 Gbytes
Core System Support Software Group
Contains the packages that provide the minimum code that is required to boot and run a networked Solaris system.
2.0 Gbytes
Reduced Network Support Software Group
Contains the packages that provide the minimum code that is required to boot and run a Solaris system with limited network service support. The Reduced Network Support Software Group provides a multiuser text-based console and system administration utilities. This software group also enables the system to recognize network interfaces, but does not activate network services.
2.0 Gbytes
Checklist for Installation
Use the following checklist to gather the information that you need to install the Solaris OS. You do not need to gather all of the information that is requested on the checklist. You only need to collect the information that applies to your system.
Use this checklist if you are performing an initial installation. If you are upgrading your system, see Checklist for Upgrading in Solaris 10 6/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning.
Table 1–7 Installation Checklist
Information for Installation
Description or Example
Answer — Defaults are noted with an asterisk (*)
Network connection
Is the system connected to a network?
Networked/Non-networked
DHCP
Can the system use Dynamic Host Configuration Protocol (DHCP) to configure its network interfaces?
DHCP provides the network parameters that are necessary for installation.
Yes/No*
If you are not using DHCP, note the network address.
IP Address
If you are not using DHCP, supply the IP address for the system.
Example: 172.31.255.255
To find this information on a running system, type the following command.
# ypmatch host-name hosts
Subnet
If you are not using DHCP, is the system part of a subnet?
If yes, what is the netmask of the subnet?
Example: 255.255.255.0
# more /etc/netmasks
IPv6
Do you want to enable IPv6 on this machine?
IPv6 is a part of the TCP/IP Internet protocol that facilitates IP addressing by adding better security and increasing Internet addresses.
Yes/No*
Host Name
Host name that you choose for the system.
# uname -n
Kerberos
Do you want to configure Kerberos security on this machine?
If yes, gather this information:
Yes/No*
Default Realm:
Administration Server:
First KDC:
(Optional) Additional KDCs:
The Kerberos service is a client-server architecture that provides secure transactions over networks.
If the system uses a name service, provide the following information.
Name Service
Which name service should this system use?
# cat /etc/nsswitch.conf
A naming service stores information in a central place, which enables users, machines, and applications to communicate across the network. Examples of information that is stored are host names and addresses or user names and passwords.
NIS+/NIS/DNS/ LDAP/None
Domain Name
Provide the name of the domain in which the system resides.
# domainname
NIS+ and NIS
Do you want to specify a name server or let the installation program find one?
If you want to specify a name server, provide the following information.
Specify One/Find One*
Server's host name:
  • For NIS clients, type the following command to display the server's host name.
    # ypwhich
  • For NIS+ clients, type the following command to display the server's host name.
    # nisping
Server's IP Address:
  • For NIS clients, type the following command to display the server's IP address.
    # ypmatch nameserver-name hosts
  • For NIS+ clients, type the following command to display the server's IP address.
    # nismatch nameserver-name
    hosts.org_dir
Network Information Service (NIS) makes network administration more manageable by providing centralized control over a variety of network information, such as machine names and addresses.
DNS
Provide IP addresses for the DNS server. You must enter at least one IP address, but you can enter up to three addresses.
To display the server's IP address, type the following command.
# getent ipnodes dns
You can enter a list of domains to search when a DNS query is made.
List of domains to be searched:
The domain name system (DNS) is the name service that the Internet provides for TCP/IP networks. DNS provides host names to the IP address service. DNS simplifies communication by using machine names instead of numerical IP addresses. DNS also serves as a database for mail administration.
LDAP
Provide the following information about your LDAP profile.
Profile Name:
Profile Server:
If you specify a proxy credential level in your LDAP profile, gather this information.
Proxy-bind distinguished name:
Proxy-bind password:
Lightweight Directory Access Protocol (LDAP) defines a relatively simple protocol for updating and searching directories that are running over TCP/IP.
Default Route
Do you want to specify a default route IP address or let the Solaris installation program find one?
The default route provides a bridge that forwards traffic between two physical networks. An IP address is a unique number that identifies each host on a network.
You have the following choices:
  • You can specify the IP address. An /etc/defaultrouter file is created with the specified IP address. When the system is rebooted, the specified IP address becomes the default route.
  • You can let the Solaris installation program detect an IP address. However, the system must be on a subnet that has a router that advertises itself by using the ICMP router discovery protocol. If you are using the command-line interface, the software detects an IP address when the system is booted.
  • You can choose None if you do not have a router or do not want the software to detect an IP address at this time. The software automatically tries to detect an IP address on reboot.
Detect one*/Specify one/None
Time Zone
How do you want to specify your default time zone?
Geographic region*
Offset from GMT
Time zone file
Root Password
Provide the root password for the system.
Locales
For which geographic regions do you want to install support?
SPARC: Power Management (only available on SPARC systems that support Power Management)
Do you want to use Power Management?
Note –
If your system has Energy Star version 3 or later, you are not prompted for this information.
Yes*/No
Automatic reboot or CD/DVD ejection
Reboot automatically after software installation?
Eject CD/DVD automatically after software installation?
Yes*/No
Yes*/No
Default or Custom Install
Do you want to perform a default installation, or customize the installation?
  • Select Default installation to format the entire hard disk and install a preselected set of software.
  • Select Custom installation to modify the hard disk layout and select the software that you want to install.
Note –
The text installer does not prompt you to select a Default or Custom Installation. To perform a default installation, accept the default values that are provided in the text installer. To perform a custom installation, edit the values in the text installer screens.
Default installation*/Custom installation
Software Group
Which Solaris Software Group do you want to install?
Entire Plus OEM
Entire*
Developer
End User
Core
Reduced Networking
Custom Package Selection
Do you want to add or remove software packages from the Solaris Software Group that you install?
Note –
When you select which packages to add or remove, you need to know about software dependencies and how Solaris software is packaged.
Select Disks
On which disks do you want to install the Solaris software?
Example: c0t0d0
x86: fdisk partitioning
Do you want to create, delete, or modify a Solaris fdisk partition?
Each disk that is selected for file system layout must have a Solaris fdisk partition.
If your system currently has a service partition, the Solaris installation program preserves the service partition by default. If you do not want to preserve the service partition, you must customize the fdisk partitions. For more information about preserving a service partition, see Default Boot-Disk Partition Layout Preserves the Service Partition in Solaris 10 6/06 Installation Guide: Network-Based Installations.
Select Disks for fdisk Partition Customization?
Yes/No*
Customize fdisk partitions?
Yes/No*
Preserve Data
Do you want to preserve any data that exists on the disks where you are installing the Solaris software?
Yes/No*
Auto-layout File Systems
Do you want the installation program to automatically lay out file systems on your disks?
If yes, which file systems should be used for auto-layout?
Example: /, /opt, /var
If no, you must provide file system configuration information.
Note –
The Solaris installation GUI lays out file systems automatically by default.
Yes*/No
Mount Remote File Systems
Does this system need to access software on another file system?
If yes, provide the following information about the remote file system.
Yes/No*
Server:
IP Address:
Remote File System:
Local Mount Point:
If you are installing through a tip line, follow these instructions.
Ensure that your window display is at least 80 columns wide and 24 rows long. For more information, see tip(1).
To determine the current dimensions of your tip window, use the stty command. For more information, see the man page, stty(1).
Check your Ethernet connection.
If the system is part of a network, verify that an Ethernet connector or similar network adapter is connected to your system.
Review the planning chapter and other relevant documentation.
Where to Find Additional Installation Information
For additional information about requirements and recommendations for installing the Solaris OS, see the following documents.
These documents are available at http://docs.sun.com.
