Solaris 10 6/06 Installation Guide: Network-Based Installations
Chapter 10 Preparing to Install From the Network (Command Reference)
This chapter lists the commands used to set up network installations. This chapter includes the following topics.
Network Installation Commands
This table describes the commands you use to install Solaris software over the network. The table also indicates to which platform the commands apply.
Command
Platform
Description
add_install_client
All
A command that adds network installation information about a system to an install server or boot server from the network. The add_install_client(1M) man page contains more information.
setup_install_server
All
A script that copies the Solaris 10 6/06 DVD or CDs to an install server's local disk or copies the boot software to a boot server. The setup_install_server(1M) man page contains more information.
(CD media only) add_to_install_server
All
A script that copies additional packages within a product tree on the CDs to the local disk on an existing install server. The add_to_install_server(1M) man page contains more information.
mount
All
A command that enables the mounting of file systems and shows the mounted file systems, including the file system on the Solaris DVD or Solaris Software and Solaris Languages CDs. The mount(1M) man page contains more information.
showmount -e
All
A command that lists all the shared file systems that are located on a remote host. The showmount(1M) man page contains more information.
uname -i
All
A command for determining a system's platform name, for example, SUNW,Ultra-5_10, or i86pc. You might need the system's platform name when you install the Solaris software. The uname(1) man page contains more information.
patchadd -C net_install_image
All
A command to add patches to the files that are located in the miniroot, Solaris_10 /Tools/Boot, on a net installation image of a DVD or CD that is created by setup_install_server. This facility enables you to patch Solaris installation commands and other miniroot-specific commands. net_install_image is the absolute path name of the net installation image. The patchadd(1M) man page contains more information.
Caution – Caution –
Don't use the patchadd -C command unless you have read the Patch README instructions or have contacted your local Sun support office.
reset
SPARC
An Open Boot PROM command for resetting the system and rebooting the machine. Or, if you boot and see a series of error messages about I/O interrupts, press the Stop and A keys at the same time, and then type reset at the ok or > PROM prompt.
banner
SPARC
An Open Boot PROM command that displays system information, such as model name, Ethernet address, and memory installed. You can issue this command only at the ok or > PROM prompt.
x86: GRUB Menu Commands for Installation
You can customize the network boot and installation of your system by editing the commands in the GRUB menu. This section describes several commands and arguments you can insert in the commands in the GRUB menu.
In the GRUB menu, you can access the GRUB command line by typing b at the prompt. A command line that is similar to the following output is displayed.
kernel /Solaris_10_x86/multiboot kernel/unix
-B install_media=192.168.2.1:/export/sol_10_x86/boot
module /platform/i86pc/boot_archive
You can edit this command line to customize your boot and installation. The following list describes several common commands you might want to use. For a complete list of boot arguments that you can use with the -B, see the eeprom(1M) man page.
Table 10–1 x86: GRUB Menu Commands and Options
Command/Option
Description and Examples
install
Insert this option before the -B option to perform a custom JumpStart installation.
kernel /Solaris_10_x86/multiboot install
url|ask
Specifies the location of the custom JumpStart files or prompts you for the location. Insert either option with the install option.
  • url - Specifies the path to the files. You can specify a URL for files that are located in the following places:
    • Local hard disk
      file://jumpstart_dir_path/compressed_config_file
      For example:
      file://jumpstart/config.tar
    • NFS server
      nfs://server_name:IP_address/jumpstart_dir_path/compressed_config_file
      For example:
      myserver:192.168.2.1/jumpstart/config.tar
    • HTTP server
      http://server_name:IP_address/jumpstart_dir_path/
      compressed_config_file&proxy_info
      • If you placed a sysidcfg file in the compressed configuration file, you must specify the IP address of the server that contains the file, as in the following example:
        http://192.168.2.1/jumpstart/config.tar
      • If you saved the compressed configuration file on an HTTP server that is behind a firewall, you must use a proxy specifier during boot. You do not need to specify an IP address for the server that contains the file. You must specify an IP address for the proxy server, as in the following example:
        http://www.shadow.com/jumpstart/config.tar&proxy=131.141.6.151
url|ask (continued)
  • ask - When used with the install option, specifies that the installation program prompt you to type the location of the compressed configuration file after the system boots and connects to the network. If you use this option, you are not able to do a completely hands off JumpStart installation.
    If you bypass the prompt by pressing Return, the Solaris installation program interactively configures the network parameters. The installation program then prompts you for the location of the compressed configuration file.
    The following example performs a custom JumpStart and boots from a network installation image. You are prompted to input the location of the configuration file after the system connects to the network.
    kernel /Solaris_10_x86/multiboot install ask
dhcp
Insert this option before the -B option to instruct the installation programs to use a DHCP server to obtain network installation information that is needed to boot the system. If you do not specify to use a DHCP server by typing dhcp, the system uses the /etc/bootparams file or the name service bootparams database. For example, you would not specify dhcp if you wanted keep a static IP address.
kernel /Solaris_10_x86/multiboot dhcp
- text
Insert this option before the -B option to perform a text-based installation in a desktop session.
kernel /Solaris_10_x86/multiboot - text
- nowin
Insert this option before the -B option to perform a text-based installation in a console session.
kernel /Solaris_10_x86/multiboot - nowin
"console=serial-console"
Use this argument with the -B option to instruct the system to use a serial console, such as ttya (COM1) or ttyb (COM2).
kernel /Solaris_10_x86/multiboot -B "console=ttya"
"ata-dma-enable=[0|1]"
Use this argument with the -B option to enable or disable Advanced Technology Attachment (ATA) or Integrated Drive Electronics (IDE) devices and Direct Memory Access (DMA) during the installation.
kernel /Solaris_10_x86/multiboot -B "ata-dma-enable=0"
"acpi-enum=[0|1]"
Use this argument with the -B option to enable or disable Advanced Configuration and Power Interface (ACPI ) power management.
kernel /Solaris_10_x86/multiboot -B "acpi-enum=0"
"acpi-cd-dma-enabled=[0|1]"
Use this argument with the -B option to enable or disable DMA for CD or DVD drives during the installation.
kernel /Solaris_10_x86/multiboot -B "acpi-cd-dma-enabled=0"
