Solaris 10 6/06 Installation Guide: Custom JumpStart and Advanced Installations
Chapter 6 Preparing Custom JumpStart Installations (Tasks)
This chapter provides step-by-step instructions about how to prepare the systems at your site from which and on which you intend to install the Solaris software by using the custom JumpStart installation method.
Task Map: Preparing Custom JumpStart Installations
Table 6–1 Task Map: Preparing Custom JumpStart Installations
Task
Description
For Instructions
Decide how to upgrade the system if a previous version of the Solaris software is installed on the system.
If a previous release of Solaris is installed on the system, you need to determine how to upgrade the system. Ensure that you know what to do before and after you upgrade a system. Planning helps you to create your profiles, begin scripts, and finish scripts.
Upgrade Planning
Create a JumpStart directory.
On a server
If you want to perform custom JumpStart installations on systems that are connected to a network, you must create a profile server. The profile server contains a JumpStart directory for the custom JumpStart files.
Creating a Profile Server for Networked Systems
On a diskette
If you want to perform custom JumpStart installations on systems that are not connected to a network, you must create a profile diskette. A profile diskette contains the custom JumpStart files.
Creating a Profile Diskette for Standalone Systems
Add rules to the rules file.
After you decide how you want each group of systems or single systems to be installed, create a rule for each group that you want to install. Each rule distinguishes a group, based on one or more system attributes. The rule links each group to a profile.
Creating the rules File
Create a profile for every rule.
A profile is a text file that defines how to install the Solaris software, for example, which software group to install on a system. Every rule specifies a profile to define how a system is to be installed with the Solaris software when the rule is matched. You usually create a different profile for every rule. However, the same profile can be used in more than one rule.
Creating a Profile
(Optional) Test the profiles.
After you create a profile, use the pfinstall(1M) command to test the profile before you use the profile to install or upgrade a system.
Testing a Profile
Validate the rules file.
The rules.ok file is a generated version of the rules file that the JumpStart program uses to match the system to be installed with a profile. You must use the check script to validate the rules file.
Validating the rules File
When setting up custom JumpStart installations for systems on the network, you need to create a directory on a server that is called a JumpStart directory. The JumpStart directory contains all of the essential custom JumpStart files, for example, the rules file, rules.ok file, and profiles. You must save the JumpStart directory in the root (/) directory of the profile server.
The server that contains a JumpStart directory is called a profile server. A profile server can be the same system as an install server or a boot server, or the server can be a completely different server. A profile server can provide custom JumpStart files for different platforms. For example, an x86 server can provide custom JumpStart files for both SPARC based systems and x86 based systems.
Note –
After you create a profile server, you must allow systems to access the server. For detailed instructions, see To Allow All Systems Access to the Profile Server.
ProcedureTo Create a JumpStart Directory on a Server
Note –
This procedure assumes that the system is running Volume Manager. If you are not using Volume Manager to manage discs, refer to System Administration Guide: Devices and File Systems for detailed information about managing removable media without Volume Manager.
Steps
  1. Log in as superuser on the server on which you want to create the JumpStart directory.
  2. Create the JumpStart directory anywhere on the server.
    # mkdir -m 755 jumpstart_dir_path
    In the command, jumpstart_dir_path is the absolute path of the JumpStart directory.
    For example, the following command creates a directory that is called jumpstart in the root (/) directory and sets the permissions to 755:
    # mkdir -m 755 /jumpstart
  3. Edit the /etc/dfs/dfstab file by adding the following entry.
    share -F nfs -o ro,anon=0 jumpstart_dir_path
    For example, the following entry shares the /jumpstart directory:
    share -F nfs -o ro,anon=0 /jumpstart
  4. Type shareall and press Enter.
  5. Determine if you want to copy examples of custom JumpStart files to your JumpStart directory.
    • If no, go to Step 8.
    • If yes, use the following decision table to determine what to do next.
    Example Locations
    Instructions
    The Solaris Operating System DVD or the Solaris Software - 1 CD for your platform
    Insert the Solaris Operating System DVD or the Solaris Software - 1 CD into the server's CD-ROM drive.
    Volume Manager automatically mounts the CD.
    An image of the Solaris Operating System DVD or the Solaris Software - 1 CD for your platform on a local disk
    Change directory to the location of the Solaris Operating System DVD or the Solaris Software - 1 image. For example, type the following command:
    cd /export/install
  6. Copy the example custom JumpStart files into the JumpStart directory on the profile server.
    # cp -r media_path/Solaris_10_606/Misc/jumpstart_sample/* jumpstart_dir_path
    media_path
    The path to the CD, DVD, or image on the local disk
    jumpstart_dir_path
    The path on the profile server where you are placing the example custom JumpStart files
    For example, the following command copies the jumpstart_sample directory into the /jumpstart directory on the profile server:
    • For SPARC based systems:
      cp -r /cdrom/cdrom0/s0/Solaris_10_606/Misc/jumpstart_sample/* /jumpstart
    • For x86 based systems:
      cp -r /cdrom/cdrom0/Solaris_10_606/Misc/jumpstart_sample/* /jumpstart
  7. Update the example JumpStart files so that the files work in your environment.
  8. Ensure that root owns the JumpStart directory and that the permissions are set to 755.
  9. Allow systems on the network to access the profile server.
Allowing All Systems Access to the Profile Server
When you create a profile server, you must ensure that systems can access the JumpStart directory on the profile server during a custom JumpStart installation. Use one of the following ways to ensure access.
Command or File
Providing Access
Instructions
add_install_client command
Each time that you add a system for network installation, use the -c option with the add_install_client command to specify the profile server.
Note –
If you are not using NFS, then you must use another means to provide access.
  • For SPARC based systems, use the boot command
  • For x86 based systems, edit the GRUB menu
Specify the location of the JumpStart directory when you boot the system
  • For SPARC based systems, use the boot command to boot the system. Specify the location of the JumpStart directory on the profile server when you boot the system. You must compress the custom JumpStart configuration files into one file. Then, save the compressed configuration file on an HTTP or HTTPS server.
  • For x86 based systems, specify the location of the JumpStart directory on the profile server when you boot the system by editing the boot entry on the GRUB menu. You must compress the custom JumpStart configuration files into one file. Then, save the compressed configuration file on an HTTP or HTTPS server.
    When you edit the GRUB menu entry, specify the location of the compressed file.
/etc/bootparams file
Add a wildcard in the /etc/bootparams file.
ProcedureTo Allow All Systems Access to the Profile Server
Use the following procedure only if you store network installation information in the following places:
If you use the following procedure, the systems must be of the same type, such as all SPARC systems.
Do not use this procedure under the following conditions:
If you have the above conditions, use the SPARC boot command or use the x86 GRUB menu.
Note –
You also can store network installation information on a DHCP server.
Steps
  1. On the installation or boot server, log in as superuser.
  2. Use a text editor to open /etc/bootparams.
  3. Add this entry.
    * install_config=server:jumpstart_dir_path
    A wildcard character that specifies that all systems have access
    server
    The host name of the profile server where the JumpStart directory is located
    jumpstart_dir_path
    The absolute path of the JumpStart directory
    For example, the following entry enables all systems to access the /jumpstart directory on the profile server that is named sherlock:
    * install_config=sherlock:/jumpstart
    Caution – Caution –
    Use of this procedure might produce the following error message when an installation client is booted:
    WARNING: getfile: RPC failed: error 5: (RPC Timed out).
    Booting From the Network, Error Messages contains details about this error message.
    All systems can now access the profile server.
A diskette that contains a JumpStart directory is called a profile diskette. A system that is not connected to the network does not have access to a profile server. As a result, you must create a JumpStart directory on a diskette if a system is not connected to a network. The system on which you create a profile diskette must have a diskette drive.
The JumpStart directory contains all of the essential custom JumpStart files, for example, the rules file, rules.ok file, and profiles. You must save the JumpStart directory in the root (/) directory of the profile diskette.
See one of the following procedures:
ProcedureSPARC: To Create a Profile Diskette
Note –
This procedure assumes that the system is running Volume Manager. If you are not using Volume Manager to manage diskettes, CDs, and DVDs, refer to System Administration Guide: Devices and File Systems for detailed information about managing removable media without Volume Manager.
Steps
  1. Log in as superuser on a SPARC based system to which a diskette drive is attached.
  2. Insert a blank diskette or a diskette that can be overwritten in the diskette drive.
  3. Mount the diskette.
    # volcheck
  4. Determine if the diskette contains a UNIX file system (UFS).
    Examine the contents of the file /etc/mnttab on the system for an entry such as the following:
    /vol/dev/diskette0/scrap  /floppy/scrap  ufs  suid,rw,largefiles,dev=1740008  927147040
    • If the entry exists, go to Step 6.
    • If the entry does not exist, go to the next step.
  5. Create a UFS on the diskette.
    # newfs /vol/dev/aliases/floppy0
  6. Determine if you want to copy examples of custom JumpStart files to your JumpStart directory.
    • If no, go to Step 9.
    Example Locations
    Instructions
    The Solaris Operating System for SPARC Platforms DVD or the Solaris Software for SPARC Platforms - 1 CD
    Insert the Solaris Operating System for SPARC Platforms DVD or the Solaris Software for SPARC Platforms - 1 CD into the server's CD-ROM drive.
    An image of the Solaris Operating System for SPARC Platforms DVD or the Solaris Software for SPARC Platforms - 1 CD on a local disk
    Change the directory to the location of the Solaris Operating System for SPARC Platforms DVD or the Solaris Software for SPARC Platforms - 1 CD image. For example, type the following command:
    cd /export/install
  7. Copy the example custom JumpStart files into the JumpStart directory on the profile diskette.
    media_path
    jumpstart_dir_path
    The path to the profile diskette where you want to place the example custom JumpStart files
    Note –
    You must place all custom JumpStart installation files in the root (/) directory on the diskette.
    For example, the following command copies the contents of jumpstart_sample on the Solaris Software for SPARC Platforms - 1 CD to the root (/) directory on a profile diskette that is named scrap:
    cp -r /cdrom/sol_10_606_sparc/s0/Solaris_10_606/Misc/jumpstart_sample/* /floppy/scrap
  8. Update the example JumpStart files on the profile diskette so that the files work in your environment.
  9. Ensure that root owns the JumpStart directory and that permissions are set to 755.
  10. Eject the diskette.
    # eject floppy
    You have completed the creation of a profile diskette. You can now update the rules file and create profiles on the profile diskette to perform custom JumpStart installations. To continue, go to Creating the rules File.
Procedurex86: To Create a Profile Diskette With GRUB
Use this procedure to create a profile diskette with GRUB. A GRUB menu is provided during the installation procedure that enables the boot process. The GRUB menu replaces the Solaris Device Configuration Assistant that might have been needed to boot a system in past releases.
Note –
Steps
  1. Log in as superuser on an x86 based system to which a diskette drive is attached.
  2. Insert a blank diskette or a diskette that can be overwritten into the diskette drive.
    # volcheck
  4. Determine if you want to copy examples of custom JumpStart files to your JumpStart directory.
    • If no, go to Step 7.
    Example Locations
    Instructions
    The Solaris Operating System for x86 Platforms DVD or the Solaris Software for x86 Platforms - 1 CD
    Insert the Solaris Operating System for x86 Platforms DVD or the Solaris Software for x86 Platforms - 1 CD into the server's CD-ROM drive.
    An image of the Solaris Operating System for x86 Platforms DVD or the Solaris Software for x86 Platforms - 1 CD on a local disk
    Change directory to the location of the Solaris Operating System for x86 Platforms DVD or the Solaris Software for x86 Platforms - 1 CD image. For example, type the following:
    cd /export/install
  5. Copy the example custom JumpStart files into the JumpStart directory on the profile diskette.
    media_path
    jumpstart_dir_path
    Note –
    You must place all custom JumpStart installation files in the root (/) directory on the profile diskette.
    For example, the following command copies the contents of jumpstart_sample on the Solaris Software for x86 Platforms - 1 CD to the root (/) directory on a profile diskette that is named scrap:
    cp -r /cdrom/sol_10_606_x86/Solaris_10_606/Misc/jumpstart_sample/* /floppy/scrap
  6. Update the example JumpStart files on the profile diskette so that the files work in your environment.
  7. Ensure that root owns the JumpStart directory and that permissions are set to 755.
  8. Eject the diskette by clicking Eject Disk in the File Manager window or by typing eject floppy on the command line.
  9. In the Removable Media Manager dialog box, click OK.
  10. Manually eject the diskette.
See Also
You have completed the creation of a profile diskette. Now you can update the rules file and create profiles on the profile diskette to perform custom JumpStart installations. To continue, go to Creating the rules File.
The rules file is a text file that contains a rule for each group of systems on which you want to install the Solaris OS. Each rule distinguishes a group of systems that are based on one or more system attributes. Each rule also links each group to a profile. A profile is a text file that defines how the Solaris software is to be installed on each system in the group. For example, the following rule specifies that the JumpStart program use the information in the basic_prof profile to install any system with the sun4u platform group.
karch sun4u - basic_prof -
The rules file is used to create the rules.ok file, which is required for custom JumpStart installations.
Note –
If you set up the JumpStart directory by using the procedures in Creating a Profile Diskette for Standalone Systems or Creating a Profile Server for Networked Systems, an example rules file is already located in the JumpStart directory. The sample rules file contains documentation and some example rules. If you use the sample rules file, ensure that you comment out the example rules you do not intend to use.
Syntax of the rules File
The rules file must have the following attributes:
The rules file can contain any of the following:
ProcedureTo Create a rules File
Steps
  1. Use a text editor to create a text file that is named rules. Or, open the sample rules file in the JumpStart directory that you created.
  2. Add a rule in the rules file for each group of systems on which you want to install the Solaris software.
    For a list of rules file keywords and values, see Rule Keywords and Values.
    A rule within a rules file must adhere to the following syntax:
    !rule_keyword rule_value && !rule_keyword rule_value ... begin  profile  finish
    A symbol that is used before a keyword to indicate negation.
    rule_keyword
    A predefined lexical unit or word that describes a general system attribute, such as host name, hostname, or memory size, memsize. rule_keyword is used with the rule value to match a system with the same attribute to a profile. For the list of rule keywords, see Rule Keywords and Values.
    rule_value
    A value that provides the specific system attribute for the corresponding rule keyword. Rule values are described in Rule Keywords and Values.
    A symbol you must use to join rule keyword and rule value pairs in the same rule (a logical AND). During a custom JumpStart installation, a system must match every pair in the rule before the rule matches.
    begin
    The name of an optional Bourne shell script that can be executed before the installation begins. If no begin script exists, you must type a minus sign (-) in this field. All begin scripts must be located in the JumpStart directory.
    Information about how to create begin scripts is presented in Creating Begin Scripts.
    profile
    The name of a text file that defines how the Solaris software is to be installed on the system when a system matches the rule. The information in a profile consists of profile keywords and their corresponding profile values. All profiles must be located in the JumpStart directory.
    Note –
    Optional ways to use the profile field are described in Using a Site-Specific Installation Program and Creating Derived Profiles With a Begin Script.
    finish
    The name of an optional Bourne shell script that can be executed after the installation is completed. If no finish script exists, you must type a minus sign (-) in this field. All finish scripts must be located in the JumpStart directory.
    Information about how to create finish scripts is presented in Creating Finish Scripts.
    At the minimum, each rule must contain the following:
    • A keyword, a value, and a corresponding profile
    • A minus sign (-) in the begin and finish fields if no begin or finish scripts are specified
  3. Save the rules file in the JumpStart directory.
  4. Ensure that root owns the rules file and that the permissions are set to 644.
rules File Example
The following example shows several example rules in a rules file. Each line has a rule keyword and a valid value for that keyword. The JumpStart program scans the rules file from top to bottom.
When the JumpStart program matches a rule keyword and value with a known system, the JumpStart program installs the Solaris software that is specified by the profile that is listed in the profile field.
Example 6–1 rule File
 # rule keywords and rule values       begin script       profile       finish script
  hostname eng-1                       -                  basic_prof    -
  network 192.168.255.255 && !model \
 'SUNW,Sun-Blade-100'                  -                  net_prof      -
  model SUNW,SPARCstation-LX           -                  lx_prof       complete
  network 192.168.2.0 && karch i86pc  setup               x86_prof      done
  memsize 64-128 && arch i386          -                  prog_prof     -
  any   -                              -                  generic_prof  -
The following list describes some of the keywords and values from this example.
hostname
The rule matches if the system's host name is eng-1. The basic_prof profile is used to install the Solaris software on the system that matches the rule.
network
The rule matches if the system is on subnet 192.168.255.255 and if the system is not a Sun Blade TM 100 (SUNW,Sun-Blade-100). The net_prof profile is used to install the Solaris software on systems that match this rule. The rule also provides an example of rule wrap, which is defined in Syntax of the rules File.
model
The rule matches if the system is a SPARCstation LX. The lx_prof profile and the complete finish script are used to install the Solaris software on systems that match this rule.
network
The rule matches if the system is on subnet 192.168.2.0 and is an x86 based sun4u system. The setup begin script, the x864u_prof profile, and the done finish script are used to install the Solaris software on systems that match the rule.
memsize
The rule matches if the system has between 64 and 128 Mbytes of memory and is an x86 based system. The prog_prof profile is used to install the Solaris software on systems that match the rule.
any
The rule matches any system that did not match the previous rules. The generic_prof profile is used to install the Solaris software on systems that match the rule. If any is used, it should always be the last rule in the rules file.
Creating a Profile
A profile is a text file that defines how to install the Solaris software on a system. A profile defines elements of the installation, for example, the software group to install. Every rule specifies a profile that defines how a system is to be installed. You can create different profiles for every rule or the same profile can be used in more than one rule.
A profile consists of one or more profile keywords and their values. Each profile keyword is a command that controls one aspect of how the JumpStart program is to install the Solaris software on a system. For example, the following profile keyword and value specify that the JumpStart program install the system as a server:
system_type  server
Note –
Sample profiles are already located in the JumpStart directory if you created the JumpStart directory by using either of these procedures:
Syntax of Profiles
A profile must contain the following:
A profile can contain the following:
ProcedureTo Create a Profile
Steps
  1. Use a text editor to create a text file. Name the file descriptively. Or, open a sample profile in the JumpStart directory that you created.
    Note –
    Ensure that the name of the profile reflects how you intend to use the profile to install the Solaris software on a system. For example, you might name the profiles basic_install, eng_profile, or user_profile.
  2. Add profile keywords and values to the profile.
    For a list of profile keywords and values, see Profile Keywords and Values.
    Note –
    Profile keywords and their values are case sensitive.
  3. Save the profile in the JumpStart directory.
  4. Ensure that root owns the profile and that the permissions are set to 644.
  5. Test the profile (optional).
    Testing a Profile contains information about testing profiles.
Profile Examples
The following examples of profiles show how to use different profile keywords and profile values to control how the Solaris software is installed on a system. Profile Keywords and Values contains a description of profile keywords and values.
Example 6–2 Mounting Remote File Systems and Adding and Deleting Packages
# profile keywords        profile values
  install_type            initial_install
  system_type             standalone
  partitioning            default
  filesys                 any 512 swap   # specify size of /swap
  cluster                 SUNWCprog
  package                 SUNWman delete
  cluster                 SUNWCacc
install_type
The install_type keyword is required in every profile.
system_type
The system_type keyword defines that the system is to be installed as a standalone system.
partitioning
The file system slices are determined by the software to be installed with the value default. The size of swap is set to 512 Mbytes and is installed on any disk, value any.
cluster
The Developer Solaris Software Group, SUNWCprog, is installed on the system.
package
If the standard man pages are mounted from the file server, s_ref, on the network, the man page packages are not to be installed on the system. The packages that contain the System Accounting utilities are selected to be installed on the system.
Example 6–3 Mounting Remote File Systems and Adding a Third-Party Package
  cluster                 SUNWCprog
  cluster                 SUNWCacc
  package                 apache_server  \
                           http://package.central/packages/apache timeout 5
install_type
system_type
partitioning
cluster
package
A third-party package is installed on the system located on an HTTP server.
Example 6–4 Specifying Where to Install File Systems
  partitioning            explicit
  filesys                 c0t0d0s0 auto /
  filesys                 c0t3d0s1 auto swap
  filesys                 any auto usr
  cluster                 SUNWCall
partitioning
The file system slices are determined by the filesys keywords, value explicit. The size of root (/) is based on the selected software, value auto, and is installed on c0t0d0s0. The size of swap is set to the necessary size and is installed on c0t3d0s1. usr is based on the selected software and the installation program determines where usr is installed, based on the value any.
cluster
The Entire Solaris Software Group, SUNWCall, is installed on the system.
Example 6–5 Upgrading and Installing Patches
  install_type             upgrade
  root_device              c0t3d0s2
  backup_media             remote_filesystem timber:/export/scratch
  package                  SUNWbcp delete
  package                  SUNWxwman add
  cluster                  SUNWCacc add
  patch                    patch_list nfs://patch_master/Solaris_10_606/patches \
                           retry 5
  locale                   de
install_type
The profile upgrades a system by reallocating disk space. In this example, disk space must be reallocated because some file systems on the system did not have enough space for the upgrade.
root_device
The root file system on c0t3d0s2 is upgraded.
backup_media
A remote system that is named timber is to be used to back up data during the disk space reallocation. For more backup-media keyword values, see backup_media Profile Keyword.
package
The binary compatibility package, SUNWbcp, is not installed on the system after the upgrade.
package
The code ensures that the X Window System man pages and the System Accounting Utilities are to be installed if they are not already installed on the system. All packages already on the system are automatically upgraded.
patch
A list of patches that are installed with the upgrade. The patch list is located on an NFS server named patch_master under the directories Solaris_10_606/patches. In case of a mount failure, the NFS mount is tried five times.
locale
The German localization packages are to be installed on the system.
Example 6–6 Reallocating Disk Space for an Upgrade
  layout_constraint        c0t3d0s2 changeable 100
  layout_constraint        c0t3d0s4 changeable
  layout_constraint        c0t3d0s5 movable
  locale                   de
install_type
root_device
backup_media
layout_constraint
The layout_constraint keywords designate that auto-layout can perform the following when auto-layout attempts to reallocate disk space for the upgrade.
  • Change slices 2 and 4. The slices can be moved to another location and the size can be changed.
  • Move slice 5. The slice can be moved to another location but its size cannot change.
package
package
locale
Example 6–7 Retrieving a Solaris Flash Archive From an HTTP Server
In the following example, the profile indicates that the custom JumpStart program retrieves the Solaris Flash archive from an HTTP server.
install_type               flash_install
archive_location           http://192.168.255.255/flasharchive/solarisarchive
filesys                    c0t1d0s0 4000 /
filesys                    c0t1d0s1 512 swap
filesys                    c0t1d0s7 free /export/home
install_type
The profile installs a Solaris Flash archive on the clone system. All files are overwritten as in an initial installation.
archive_location
The Solaris Flash archive is retrieved from an HTTP server.
partitioning
The file system slices are determined by the filesys keywords, value explicit. The size of root (/) is based on the size of the Solaris Flash archive. The root file system is installed on c0t1d0s0. The size of swap is set to the necessary size and is installed on c0t1d0s1. /export/home is based on the remaining disk space. /export/home is installed on c0t1d0s7.
Example 6–8 Retrieving a Solaris Flash Archive From a Secure HTTP Server
In the following example, the profile indicates that the custom JumpStart program retrieves the Solaris Flash archive from a secure HTTP server.
archive_location           https://192.168.255.255/solarisupdate.flar
install_type
archive_location
The compressed Solaris Flash archive is retrieved from a secure HTTP server.
partitioning
The file system slices are determined by the filesys keywords, value explicit. The size of root (/) is based on the size of the Solaris Flash archive. The size of swap is set to the necessary size and is installed on c0t1d0s1. /export/home is based on the remaining disk space. /export/home is installed on c0t1d0s7.
Example 6–9 Retrieving a Solaris Flash Archive and Installing a Third-Party Package
package                    SUNWnew http://192.168.254.255/Solaris_10_606 timeout 5
install_type
archive_location
partitioning
package
The SUNWnew package is added from the Solaris_10_606 directory from the HTTP server 192.168.254.255.
Example 6–10 Retrieving a Solaris Flash Differential Archive From an NFS Server
In the following example, the profile indicates that the custom JumpStart program retrieves the Solaris Flash archive from an NFS server. The flash_update keyword indicates that this is a differential archive. A differential archive installs only the differences between two system images.
install_type               flash_update
archive_location           nfs installserver:/export/solaris/flasharchive \
                           /solarisdiffarchive
no_master_check
install_type
The profile installs a Solaris Flash differential archive on the clone system. Only files that are specified by the archive are installed.
archive_location
The Solaris Flash archive is retrieved from an NFS server.
no_master_check
The clone system is not checked for a valid system image. A valid system image would have been built from the original master system.
Example 6–11 Creating an Empty Boot Environment
In the following example, the profile indicates that the custom JumpStart program creates an empty boot environment. An empty boot environment contains no file systems and no copy from the current boot environment occurs. The boot environment can be populated later with a Solaris Flash archive and then activated.
  cluster                 SUNWCall
  bootenv createbe bename second_BE \
  filesystem /:/dev/dsk/c0t1d0s0:ufs \
  filesystem -:/dev/dsk/c0t1d0s0:swap \
  filesystem /export:shared:ufs
partitioning
cluster
bootenv createbe
An empty, inactive boot environment is set up on disk c0t1d0. File systems for root (/), swap, and /export are created, but left empty. This second boot environment can be installed with a Solaris Flash archive at a later time. The new boot environment can then be activated to become the current boot environment.
For keyword values and background about using this keyword, see the following references:
Example 6–12 Creating RAID-1 Volumes When Installing a Solaris Flash Archive
In the following example, the profile indicates that the custom JumpStart program uses Solaris Volume Manager technology to create RAID-1 volumes (mirrors) for the root (/), swap, /usr and /export/home file systems. A Solaris Flash archive is installed on the boot environment.
  arhcive_location        nfs server:/export/home/export/flash.s10.SUNWCall
  filesys                 mirror:d10 c0t0d0s0 c0t1d0s0 4096 /
  filesys                 mirror c0t0d0s1 2048 swap
  filesys                 mirror:d30 c0t0d0s3 c0t1d0s3 4096 /usr
  filesys                 mirror:d40 c0t0d0s4 c0t1d0s4 4096 /usr
  filesys                 mirror:d50 c0t0d0s5 c0t1d0s5 free /export/home
  metadb                  c0t1d0s7 size 8192 count 3
install_type
archive_location
partitioning
filesys
The root (/) file system is created and mirrored on the slices c0t0d0s0 and c0t1d0s0. The size of the root (/) file system is set to 4096 Mbytes. The RAID-1 volume that mirrors c0t0d0s0 and c0t1d0s0 is named d10.
filesys
The swap file system is created and mirrored on the slice c0t0d0s1, and is sized at 2048 Mbytes. The custom JumpStart program assigns a name to the mirror.
filesys
The /usr file system is created and mirrored on the slices c0t1d0s3 and c0t0d0s3. The size of the /usr file system is set to 4096 Mbytes. The RAID-1 volume is named d30.
filesys
The /usr file system is created and mirrored on the slices c0t1d0s4 and c0t0d0s4. The size of the /usr file system is set to 4096 Mbytes. The RAID-1 volume is named d40.
metadb
Three state database replicas (metadbs) are installed on slice c0t1d0s7, and are sized at 8192 blocks (4 Mbytes).
Example 6–13 Creating a RAID-1 Volume to Mirror the Root File System
In the following example, the profile indicates that the custom JumpStart program uses Solaris Volume Manager technology to create a RAID-1 volume (mirror) for the root (/) file system.
  cluster                 SUNWCXall
  filesys                 mirror:d30 c0t1d0s0 c0t0d0s0  /
  filesys                 c0t0d0s3 512 swap
  metadb                  c0t0d0s4 size 8192 count 4
  metadb                  c0t1d0s4 size 8192 count 4
cluster
The Entire Solaris Software Plus OEM Support software group, SUNWCXall, is installed on the system.
filesys
The root (/) file system is created and mirrored on the slices c0t1d0s0 and c0t0d0s0. The RAID-1 volume that mirrors c0t1d0s0 and c0t0d0s0 is named d30. The custom JumpStart program assigns names to the two submirrors.
filesys
The swap file system is created and mirrored on the slice c0t0d0s3, and is sized at 512 Mbytes.
metadb
Four state database replicas (metadbs) are installed on slice c0t0d0s4, and are sized at 8192 blocks (4 Mbytes).
metadb
Four state database replicas (metadbs) are installed on slice c0t1d0s4, and are sized at 8192 blocks (4 Mbytes).
Example 6–14 Creating RAID-1 Volumes to Mirror Multiple File Systems
In the following example, the profile indicates that the custom JumpStart program uses Solaris Volume Manager technology to create RAID-1 volumes (mirrors) for the root (/), swap, and /usr file systems.
  cluster                 SUNWCXall
  filesys                 mirror:d100 c0t1d0s0 c0t0d0s0 200 /
  filesys                 c0t1d0s5 500 /var
  filesys                 c0t0d0s5 500
  filesys                 mirror c0t0d0s1 512 swap
  metadb                  c0t0d0s3 size 8192 count 5
  filesys                 mirror c0t1d0s4 c0t0d0s4 2000 /usr
  filesys                 c0t0d0s7 free
cluster
filesys
The root (/) file system is created and mirrored on the slices c0t1d0s0 and c0t0d0s0. The size of the root (/) file system is set to 200 Mbytes. The RAID-1 volume that mirrors c0t1d0s0 and c0t0d0s0 is named d100.
filesys
The /var file system is installed on the slice c0t1d0s5 and is sized at 500 Mbytes. The root (/) file system is created and mirrored on the slices c0t1d0s0 and c0t0d0s0. The size of the root (/) file system is set to 200 Mbytes. The RAID-1 volume that mirrors c0t1d0s0 and c0t0d0s0 is named d100.
filesys
The swap file system is created and mirrored on the slice c0t0d0s1, and is sized at 512 Mbytes. The custom JumpStart program assigns a name to the mirror.
metadb
Five state database replicas (metadbs) are installed on slice c0t0d0s3, and are sized at 8192 blocks (4 Mbytes).
filesys
The /usr file system is created and mirrored on the slices c0t1d0s4 and c0t0d0s4. The size of the /usr file system is set to 2000 Mbytes. The custom JumpStart program assigns a name to the mirror.
Example 6–15 x86: Using the fdisk Keyword
  fdisk                 c0t0d0 0x04 delete
  fdisk                 c0t0d0 solaris maxfree
  cluster               SUNWCall
  cluster               SUNWCacc delete
fdisk
All fdisk partitions of type DOSOS16 (04 hexadecimal) are deleted from the c0t0d0 disk.
fdisk
A Solaris fdisk partition is created on the largest contiguous free space on the c0t0d0 disk.
cluster
The Entire Distribution software group, SUNWCall, is installed on the system.
cluster
The system accounting utilities, SUNWCacc, are not to be installed on the system.
Testing a Profile
After you create a profile, use the pfinstall(1M) command to test the profile. Test the profile before you use the profile to install or upgrade a system. Testing a profile is especially useful when you are creating upgrade profiles that reallocate disk space.
By looking at the installation output that is generated by pfinstall, you can quickly determine if a profile works as you intended. For example, use the profile to determine if a system has enough disk space to upgrade to a new release of the Solaris software before you perform the upgrade on that system.
pfinstall enables you to test a profile against the following:
ProcedureTo Create a Temporary Solaris Environment to Test a Profile
To test a profile for a particular Solaris release successfully and accurately, you must test a profile within the Solaris environment of the same release. For example, if you want to test a Solaris initial installation profile, run the pfinstall command on a system that is running the Solaris OS.
You need to create a temporary installation environment if you are testing a profile under one of the following conditions:
Steps
  1. Boot a system from an image of one of the following:
    • Solaris Operating System for SPARC Platforms DVD
    • Solaris Software for SPARC Platforms - 1 CD
    • Solaris Operating System for x86 Platforms DVD
    • Solaris Software for x86 Platforms - 1 CD
    Note –
    If you want to test an upgrade profile, boot the system that you are upgrading.
  2. Respond to the system identification questions.
  3. To exit from the installation program, type ! at the following prompt.
    The Solaris installation program  will assist you in installing software for Solaris.
    <Press ENTER to continue> {"!" exits}
  4. Execute the pfinstall command from the shell. For details about using the pfinstall command, see Step 7 in To Test a Profile.
ProcedureTo Test a Profile
x86 only –
If you are using the locale keyword, the pfinstall -D command fails to test the profile. For a workaround, see the error message “could not select locale,” in the section, Upgrading the Solaris OS.
Steps
  1. Locate a system on which to test the profile that is the same type of platform, SPARC or x86, for which the profile was created.
    If you are testing an upgrade profile, you must test the profile on the actual system that you intend to upgrade.
  2. Use the following decision table to determine what to do next.
    Test Scenario
    Instructions
    Test an initial installation profile and have a system that is running the Solaris 10 6/06 software.
    Become superuser on the system and go to Step 5.
    Test an upgrade profile, or you do not have a system that is running Solaris 10 6/06 to test an initial installation profile.
    Create a temporary Solaris 10 6/06 environment to test the profile. For details, see To Create a Temporary Solaris Environment to Test a Profile. Then, go to Step 3.
  3. Create a temporary mount point.
    # mkdir /tmp/mnt
  4. Mount the directory that contains the profile or profiles that you want to test.
    Mount Scenario
    Typing Instructions
    Mount a remote NFS file system for systems on the network.
    mount -F nfs server_name:path /tmp/mnt
    SPARC: Mount a UFS-formatted diskette.
    mount -F ufs /dev/diskette /tmp/mnt
    Mount a PCFS-formatted diskette.
    mount -F pcfs /dev/diskette /tmp/mnt
  5. To test the profile with a specific system memory size, set SYS_MEMSIZE to the specific memory size in Mbytes.
    # SYS_MEMSIZE=memory_size
    # export SYS_MEMSIZE
  6. Did you mount a directory in Step 4?
    • If yes, change the directory to /tmp/mnt.
      # cd /tmp/mnt
    • If no, change the directory to where the profile is located, which is usually the JumpStart directory.
      # cd jumpstart_dir_path
  7. Test the profile with the pfinstall(1M) command.
    # /usr/sbin/install.d/pfinstall -D:-d disk_config_file -c path profile
    Caution – Caution –
    You must include the -d or -D option. If you do not include one of these options, pfinstall uses the profile you specify to install the Solaris software. All of the data on the system is overwritten.
    -D
    pfinstall uses the current system's disk configuration to test the profile. You must use the -D option to test an upgrade profile.
    -d disk_config_file
    pfinstall uses the disk configuration file, disk_config_file, to test the profile. If disk_config_file is not located in the directory where pfinstall is run, you must specify the path.
    For instructions about how to create a disk configuration file, see Creating Disk Configuration Files.
    Note –
    You cannot use the -d disk_config_file option with an upgrade profile, install_type upgrade. You must always test an upgrade profile against a system's disk configuration, that is, you must use the -D option.
    -c path
    The path to the Solaris software image. You use this option, for example, if the system is using Volume Manager to mount the Solaris Software - 1 CD for your platform.
    Note –
    The -c option is not required if you booted from a Solaris Operating System DVD or a Solaris Software - 1 CD image for your platform. The DVD or CD image is mounted on /cdrom as part of the booting process.
    profile
    The name of the profile to test. If profile is not in the directory where pfinstall is being run, you must specify the path.
Profile Test Examples
The following example shows how to use pfinstall to test a profile that is named basic_prof. The profile is tested against the disk configuration on a system on which the Solaris 10 6/06 software is installed. The basic_prof profile is located in the /jumpstart directory, and the path to the Solaris Operating System DVD image is specified because Volume Manager is being used.
Example 6–16 Profile Test Using a Solaris 10 6/06 System
# cd /jumpstart
# /usr/sbin/install.d/pfinstall -D -c /cdrom/pathname basic_prof
The following example shows how to use pfinstall to test the profile that is named basic_prof on a Solaris 10 6/06 system. The test is performed against the 535_test disk configuration file. The test checks for 64 Mbytes of system memory. This example uses a Solaris Software for SPARC Platforms - 1 CD or Solaris Software for x86 Platforms - 1 CD image that is located in the /export/install directory.
Example 6–17 Profile Test Using a Disk Configuration File
# SYS_MEMSIZE=64
# /usr/sbin/install.d/pfinstall -d 535_test -c /export/install basic_prof
Before you can use a profile and rules file, you must run the check script to validate that the files are set up correctly. If all rules and profiles are correctly set up, the rules.ok file is created, which is required by the custom JumpStart installation software to match a system to a profile.
Table 6–2 describes what the check script does.
Table 6–2 What Happens When You Use the check Script
Stage
Description
The rules file is checked for syntax.
check verifies that the rule keywords are legitimate and that the begin, class, and finish fields are specified for each rule. The begin and finish fields can consist of a minus sign (-) instead of a file name.
If no errors are found in the rules file, each profile that is specified in the rules is checked for syntax.
If no errors are found, check creates the rules.ok file from the rules file, removes all comments and blank lines, retains all rules, and adds the following comment line at the end:
# version=2 checksum=num
ProcedureTo Validate the rules File
Steps
  1. Ensure that the check script is located in the JumpStart directory.
    Note –
    The check script is in the Solaris_10_606/Misc/jumpstart_sample directory on the Solaris Operating System DVD or on the Solaris Software - 1 CD.
  2. Change the directory to the JumpStart directory.
  3. Run the check script to validate the rules file:
    $ ./check -p path -r file_name
    -p path
    Validates the rules by using the check script from the Solaris software image instead of the check script from the system you are using. path is the image on a local disk or a mounted Solaris Operating System DVD or a Solaris Software - 1 CD.
    Use this option to run the most recent version of check if your system is running a previous version of Solaris.
    -r file_name
    Specifies a rules file other than the one that is named rules. Using this option, you can test the validity of a rule before you integrate the rule into the rules file.
    As the check script runs, the script reports the checking of the validity of the rules file and each profile. If no errors are encountered, the script reports the following information.
    The custom JumpStart configuration is ok
  4. Ensure that root owns the rules.ok file and that the permissions are set to 644.
See Also
After you validate the rules file, you can learn more about optional custom JumpStart features in Chapter 7, Using Optional Custom JumpStart Features (Tasks). You can learn about performing custom JumpStart installations in Chapter 9, Performing a Custom JumpStart Installation (Tasks).
