Solaris 10 11/06 Installation Guide: Network-Based Installations
Network Installation Introduction
This section provides you with information you need before you can perform an installation from the network. Network installations enable you to install the Solaris software from a system, called an install server, that has access to the Solaris 10 11/06 disc images. You copy the contents of the Solaris 10 11/06 DVD or CD media to the install server's hard disk. Then, you can install the Solaris software from the network by using any of the Solaris installation methods.
Required Servers for Network Installation
To install the Solaris OS from the network, the systems to be installed require the following servers to be present on the network.
Figure 4–1 illustrates the servers that are typically used for network installation. Note that this sample network does not include a DHCP server.
Figure 4–1 Network Installation Servers
This illustration depicts the servers that are typically
