Solaris 10 11/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning
To Create a Boot Environment
The source boot environment is named c0t4d0s0 by using the -c option. Naming the source boot environment is required only when the first boot environment is created. For more information about naming using the -c option, see the description in “To Create a Boot Environment for the First Time” Step 2.
The new boot environment is named c0t15d0s0. The -A option creates a description that is associated with the boot environment name.
The root (/) file system is copied to the new boot environment. Also, a new swap slice is created rather than sharing the source boot environment's swap slice.
# lucreate -A 'BE_description' -c /dev/dsk/c0t4d0s0 -m /:/dev/dsk/c0t15d0s0:ufs\
-m -:/dev/dsk/c0t15d0s1:swap -n /dev/dsk/c0t15d0s0
