In this example, the source boot environment is named c0t4d0s0. The root (/) file system is copied to the new boot environment. Also, a new swap slice is created instead of sharing the source boot environment's swap slice.
Become superuser or assume an equivalent role.
Display the character user interface:
# /usr/sbin/lu |
The Solaris Live Upgrade Main Menu is displayed.
From the main menu, select Create.
Name of Current Boot Environment: c0t4d0s0 Name of New Boot Environment: c0t15d0s0 |
Press F3.
The Configuration menu is displayed.
To select a slice from the configuration menu, press F2.
The Choices menu is displayed.
Choose slice 0 from disk c0t15d0 for the root (/) file system.
From the configuration menu, create a new slice for swap on c0t15d0 by selecting a swap slice to be split.
To select a slice for swap, press F2. The Choices menu is displayed.
Select slice 1 from disk c0t15d0 for the new swap slice.
Press F3 to create the new boot environment.
