Solaris 10 11/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning
ProcedureTo Determine a Boot Environment Name From a Description in a File
The following command displays the boot environment's name that is associated with a file. The file contains the description of the boot environment.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # /usr/sbin/ludesc -f  file_name
    -f file_name
    Specifies the name of the file that contains the description of the boot environment.
Example 7–8 Determining a Boot Environment Name From a Description in a File
In this example, the name of the boot environment, second_disk, is determined by using the -f option and the name of the file that contains the description.
# /usr/sbin/ludesc -f rose.gif
second_disk
