You can install the Solaris Live Upgrade packages by using the following:
The pkgadd command. The Solaris Live Upgrade packages are SUNWlur and SUNWluu, and these packages must be installed in that order.
An installer on the Solaris Operating System DVD, the Solaris Software - 2 CD, or a net installation image.
Be aware that the following patches might need to be installed for the correct operation of Solaris Live Upgrade.
Description |
For More Information |
Caution: Correct operation of Solaris Live Upgrade requires that a limited set of patch revisions be installed for a particular OS version. Before installing or running Solaris Live Upgrade, you are required to install these patches. x86 only – If this set of patches is not installed, Solaris Live Upgrade fails and you might see the following error message. If you don't see the following error message, necessary patches still might not be installed. Always verify that all patches listed on the SunSolve info doc have been installed before attempting to install Solaris Live Upgrade.
The patches listed in info doc 72099 are subject to change at any time. These patches potentially fix defects in Solaris Live Upgrade, as well as fix defects in components that Solaris Live Upgrade depends on. If you experience any difficulties with Solaris Live Upgrade, please check and make sure that you have the latest Solaris Live Upgrade patches installed. |
Ensure that you have the most recently updated patch list by consulting http://sunsolve.sun.com. Search for the info doc 72099 on the SunSolve web site. |
If you are running the Solaris 8 or 9 OS, you might not be able to run the Solaris Live Upgrade installer. These releases do not contain the set of patches needed to run the Java 2 runtime environment. You must have the recommended patch cluster for the Java 2 runtime environment recommended to run the Solaris Live Upgrade installer and install the packages. |
To install the Solaris Live Upgrade packages, use the pkgadd command. Or install, for the Java 2 runtime environment, the recommended patch cluster. The patch cluster is available on http://sunsolve.sun.com. |
For instructions about installing the Solaris Live Upgrade software, see Installing Solaris Live Upgrade.
If you have problems with Solaris Live Upgrade, you might be missing packages. In the following table, check that your OS has the listed packages , which are required to use Solaris Live Upgrade.
For the Solaris 10 release:
If you install one of the following software groups, these software groups contain all the required Solaris Live Upgrade packages.
Entire Solaris Software Group Plus OEM Support
Developer Solaris Software Group
End User Solaris Software Group
If you install one of these Software Groups, then you might not have all the packages required to use Solaris Live Upgrade.
Core System Support Software Group
Reduced Network Support Software Group
For information about software groups, see Disk Space Recommendations for Software Groups in Solaris 10 11/06 Installation Guide: Planning for Installation and Upgrade.
Table 3–2 Required Packages for Solaris Live Upgrade
To check for packages on your system, type the following command.
% pkginfo package_name |
