Solaris 10 11/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning
ProcedureTo Install a Solaris Flash Archive on a Boot Environment (Character User Interface)
  1. Install the Solaris Live Upgrade SUNWlur and SUNWluu packages on your system. These packages must be from the release you are upgrading to. For step-by-step procedures, see To Install Solaris Live Upgrade With the pkgadd Command.
  2. From the Solaris Live Upgrade main menu, select Flash.
    The Flash an Inactive Boot Environment menu is displayed.
  3. Type the name of the boot environment where you want to install the Solaris Flash archive and the location of the installation media:
    Name of Boot Environment: Solaris_10
    Package media: /net/install-svr/export/Solaris_10/latest
  4. Press F1 to add an archive.
    An Archive Selection submenu is displayed.
    Location            - Retrieval Method
    <No Archives added> - Select ADD to add archives
    This menu enables you to build a list of archives. To add or remove archives, proceed with the following steps.
    1. To add an archive to the menu, press F1.
      A Select Retrieval Method submenu is displayed.
      HTTP
      NFS
      Local File
      Local Tape
      Local Device
    2. On the Select Retrieval Method menu, select the location of the Solaris Flash archive.
      Media Selected
      Prompt
      HTTP
      Specify the URL and proxy information that is needed to access the Solaris Flash archive.
      NFS
      Specify the path to the network file system where the Solaris Flash archive is located. You can also specify the archive file name.
      Local file
      Specify the path to the local file system where the Solaris Flash archive is located.
      Local tape
      Specify the local tape device and the position on the tape where the Solaris Flash archive is located.
      Local device
      Specify the local device, the path to the Solaris Flash archive, and the type of file system on which the Solaris Flash archive is located.
      A Retrieval submenu is displayed, similar to the following example, which depends on the media you selected.
      NFS Location:
    3. Type the path to the archive, as in the following example.
      NFS Location: host:/path/to archive.flar
    4. Press F3 to add the archive to the list.
    5. (Optional) To remove an archive from the menu, press F2.
    6. When the list contains the archives that you want to install, press F6 to exit.
  5. Press F3 to install one or more archives.
    The Solaris Flash archive is installed on the boot environment. All files on the boot environment are overwritten, except for shareable files.
    The boot environment is ready for activation. See To Activate a Boot Environment (Character User Interface).
