Activating a boot environment makes it bootable on the next reboot of the system. You can also switch back quickly to the original boot environment if a failure occurs on booting the newly active boot environment. See Chapter 6, Failure Recovery: Falling Back to the Original Boot Environment (Tasks).
Description |
For More Information |
Use this procedure to activate a boot environment and use a character user interface (CUI). Note – The first time you activate a boot environment, the Activate menu or the luactivate command must be used. | |
Use this procedure to activate a boot environment with the luactivate command. Note – The first time you activate a boot environment, the Activate menu or the luactivate command must be used. | |
Use this procedure to activate a boot environment and force a synchronization of files. Note – Files are synchronized with the first activation. If you switch boot environments after the first activation, files are not synchronized. |
To Activate a Boot Environment and Synchronize Files (Command-Line Interface) |
x86: Use this procedure to activate a boot environment with the GRUB menu. Note – A GRUB menu can facilitate switching from one boot environment to another. A boot environment appears in the GRUB menu after the first activation. |
x86: To Activate a Boot Environment With the GRUB Menu (Command-Line Interface) |
To successfully activate a boot environment, that boot environment must meet the following conditions:
Description |
The boot environment must have a status of “complete.” |
To check status, see Displaying the Status of All Boot Environments. |
If the boot environment is not the current boot environment, you cannot have mounted the partitions of that boot environment by using the luumount or mount commands. |
To view man pages, see lumount(1M) or mount(1M). |
The boot environment that you want to activate cannot be involved in a comparison operation. |
For procedures, see Comparing Boot Environments. |
If you want to reconfigure swap, make this change prior to booting the inactive boot environment. By default, all boot environments share the same swap devices. |
To reconfigure swap, see one of the following procedures:
If you have an x86 based system, you can also activate with the GRUB menu. Note the following exceptions:
If a boot environment was created with the Solaris 8, 9, or 10 3/05 release, the boot environment must always be activated with the luactivate command or the Activate menu. These older boot environments do not display on the GRUB menu.
The first time you activate a boot environment, you must use the luactivate command or the Activate menu. The next time you boot, that boot environment's name is displayed in the GRUB main menu. You can thereafter switch to this boot environment by selecting the appropriate entry in the GRUB menu.
See x86: Activating a Boot Environment With the GRUB Menu.
The first time you boot from a newly created boot environment, Solaris Live Upgrade software synchronizes the new boot environment with the boot environment that was last active. “Synchronize” means that certain critical system files and directories are copied from the last-active boot environment to the boot environment being booted. Solaris Live Upgrade does not perform this synchronization after this initial boot unless you request to do so when prompted to force a synchronization.
For more information about synchronization, see Synchronizing Files Between Boot Environments.
From the Solaris Live Upgrade main menu, select Activate.
Type the name of the boot environment to make active:
Name of Boot Environment: Solaris_10 Do you want to force a Live Upgrade sync operations: no |
You can either continue or force a synchronization of files.
Press Return to continue.
The first time that the boot environment is booted, files are automatically synchronized.
You can force a synchronization of files, but use this feature with caution. Operating systems on each boot environment must be compatible with files that are being synchronized. To force a synchronization of files, type:
Do you want to force a Live Upgrade sync operations: yes |
Use a forced synchronization with great care, because you might not be aware of or in control of changes that might have occurred in the last-active boot environment. For example, if you were running Solaris 10 11/06 software on your current boot environment and booted back to a Solaris 9 release with a forced synchronization, files could be changed on the Solaris 9 release. Because files are dependent on the release of the OS, the boot to the Solaris 9 release could fail because the Solaris 10 11/06 files might not be compatible with the Solaris 9 files.
Press F3 to begin the activation process.
The new boot environment is activated at the next reboot.
To activate the inactive boot environment, reboot:
# init 6 |
The following procedure switches a new boot environment to become the currently running boot environment.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
To activate the boot environment, type:
# /sbin/luactivate BE_name |
Specifies the name of the boot environment that is to be activated
Reboot.
# init 6 |
Use only the init or shutdown commands to reboot. If you use the reboot, halt, or uadmin commands, the system does not switch boot environments. The last-active boot environment is booted again.
In this example, the second_disk boot environment is activated at the next reboot.
# /sbin/luactivate second_disk # init 6 |
The first time you boot from a newly created boot environment, Solaris Live Upgrade software synchronizes the new boot environment with the boot environment that was last active. “Synchronize” means that certain critical system files and directories are copied from the last-active boot environment to the boot environment being booted. Solaris Live Upgrade does not perform this synchronization after the initial boot, unless you force synchronization with the luactivate command and the -s option.
When you switch between boot environments with the GRUB menu, files also are not synchronized. You must use the following procedure to synchronize files.
# /sbin/luactivate -s BE_name |
Forces a synchronization of files between the last-active boot environment and the new boot environment. The first time that a boot environment is activated, the files between the boot environment are synchronized With subsequent activations, the files are not synchronized unless you use the -s option.
Use this option with great care, because you might not be aware of or in control of changes that might have occurred in the last-active boot environment. For example, if you were running Solaris 10 11/06 software on your current boot environment and booted back to a Solaris 9 release with a forced synchronization, files could be changed on the Solaris 9 release. Because files are dependent on the release of the OS, the boot to the Solaris 9 release could fail because the Solaris 10 11/06 files might not be compatible with the Solaris 9 files.
Specifies the name of the boot environment that is to be activated.
Reboot.
# init 6 |
In this example, the second_disk boot environment is activated at the next reboot and the files are synchronized.
# /sbin/luactivate -s second_disk # init 6 |
A GRUB menu provides an optional method of switching between boot environments. The GRUB menu is an alternative to activating (booting) with the luactivate command or the Activate menu. The table below notes cautions and limitations when using the GRUB menu.
Table 5–3 x86: Activating With the GRUB Menu Summary
Task |
Description |
Caution |
After you have activated a boot environment, do not change the disk order in the BIOS. Changing the order might cause the GRUB menu to become invalid. If this problem occurs, changing the disk order back to the original state fixes the GRUB menu. | |
Activating a boot environment for the first time |
The first time you activate a boot environment, you must use the luactivate command or the Activate menu. The next time you boot, that boot environment's name is displayed in the GRUB main menu. You can thereafter switch to this boot environment by selecting the appropriate entry in the GRUB menu. | |
Synchronizing files |
The first time you activate a boot environment, files are synchronized between the current boot environment and the new boot environment. With subsequent activations, files are not synchronized. When you switch between boot environments with the GRUB menu, files also are not synchronized. You can force a synchronization when using the luactivate command with the -s option. |
Boot environments created before the Solaris 10 1/06 release |
If a boot environment was created with the Solaris 8, 9, or 10 3/05 release, the boot environment must always be activated with the luactivate command or the Activate menu. These older boot environments do not display on the GRUB menu. | |
Editing or customizing the GRUB menu entries |
The menu.lst file contains the information that is displayed in the GRUB menu. You can revise this file for the following reasons:
Note – If you want to change the GRUB menu, you need to locate the menu.lst file. For step-by-step instructions, see x86: Locating the GRUB Menu's menu.lst File (Tasks). Caution – Do not use the GRUB menu.lst file to modify Solaris Live Upgrade entries. Modifications could cause Solaris Live Upgrade to fail. Although you can use the menu.lst file to customize booting behavior, the preferred method for customization is to use the eeprom command. If you use the menu.lst file to customize, the Solaris OS entries might be modified during a software upgrade. Changes to the file could be lost. |
You can switch between two boot environments with the GRUB menu. Note the following limitations:
The first activation of a boot environment must be done with the luactivate command or the Activate menu. After the initial activation, the boot environment is displayed on the GRUB menu. The boot environment can then be booted from the GRUB menu.
Caution - Switching to a boot environment with the GRUB menu bypasses synchronization. For more information about synchronizing files, see link Forcing a Synchronization Between Boot Environments.
If a boot environment was created with the Solaris 8, 9, or 10 3/05 release, the boot environment must always be activated with the luactivate command or the Activate menu. These older boot environments are not displayed on the GRUB menu.
Reboot the system.
# init 6 |
The GRUB main menu is displayed. The two operating systems are listed, Solaris and second_disk, which is a Solaris Live Upgrade boot environment. The failsafe entries are for recovery, if for some reason the primary OS does not boot.
GNU GRUB version 0.95 (616K lower / 4127168K upper memory) +-------------------------------------------------------------------+ |Solaris | |Solaris failsafe | |second_disk | |second_disk failsafe | +-------------------------------------------------------------------+ Use the ^ and v keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. |
To activate a boot environment, use the arrow key to select the desired boot environment and press Return.
The selected boot environment is booted and becomes the active boot environment.
