Now you must add rules to the rules file. The Solaris installation program uses the rules to select the correct installation (profile) for each system during a custom JumpStart installation.
At this site, each department is located on its own subnet and has its own network address. The engineering department is located on subnet 255.222.43.0. The marketing department is located on 255.222.44.0. You can use this information to control how the engineering and marketing systems are installed with the Solaris 10 11/06 software. In the /jumpstart directory, you edit the rules file, delete all of the example rules, and add the following lines to the file:
network 255.222.43.0 - eng_prof - network 255.222.44.0 - marketing_prof - |
Basically, these rules state that systems on the 255.222.43.0 network are to be installed with the Solaris 10 11/06 software by using the eng_prof profile. The systems on the 255.222.44.0 network are to be installed with the Solaris 10 11/06 software by using the marketing_prof profile.
You can use the sample rules to use a network address to identify the systems to be installed with the Solaris 10 11/06 software by using eng_prof and marketing_prof, respectively. You can also use host names, memory size, or model type as the rule keyword. Table 8–1 contains a complete list of keywords you can use in a rules file.
