Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations
no_master_check Profile Keyword (Installing Solaris Flash Archives)
no_master_check
When installing a clone system with a Solaris Flash differential archive, you can use the no_master_check keyword to ignore checking the clone system to make sure it was built from the original master system. Avoid using this keyword unless you are sure the clone system is a duplicate of the original master system.
For information about installing Solaris Flash differential archives, see To Prepare to Install a Solaris Flash Archive With a Custom JumpStart Installation.
