Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations
Creating Finish Scripts
A finish script is a user-defined Bourne shell script that you specify in the rules file. A finish script performs tasks after the Solaris software is installed on a system, but before the system reboots. You can use finish scripts only when using custom JumpStart to install Solaris.
Tasks that you can perform with a finish script include the following:
Important Information About Finish Scripts
ProcedureTo Add Files With a Finish Script
Through a finish script, you can add files from the JumpStart directory to an already installed system. You can add the files because the JumpStart directory is mounted on the directory that is specified by the SI_CONFIG_DIR variable. The directory is set to /tmp/install_config by default.
Note –
You can also replace files by copying files from the JumpStart directory to already existing files on the installed system.
  1. Copy all of the files that you are adding to the installed system to the JumpStart directory.
  2. Insert the following line in the finish script for each file that you want to be copied to the newly installed file system hierarchy:
    cp ${SI_CONFIG_DIR}/file_name /a/path_name
Example 4–2 Adding a File With a Finish Script
For example, assume you have a special application, site_prog, developed for all users at your site. If you place a copy of site_prog into the JumpStart directory, the following line in a finish script copies site_prog from the JumpStart directory into a system's /usr/bin directory:
cp ${SI_CONFIG_DIR}/site_prog  /a/usr/bin
Adding Packages or Patches With a Finish Script
You can create a finish script to automatically add packages or patches after the Solaris software is installed on a system. By adding packages with a finish script, you reduce time and ensure consistency in which packages and patches are installed on different systems at your site.
When you use the pkgadd(1M) or patchadd(1M) commands in finish scripts, use the -R option to specify /a as the root path.
Example 4–3 Adding Packages With a Finish Script
  #!/bin/sh
  BASE=/a
  MNT=/a/mnt
  ADMIN_FILE=/a/tmp/admin
  mkdir ${MNT}
  mount -f nfs sherlock:/export/package ${MNT}
  cat >${ADMIN_FILE} <<DONT_ASK
  mail=root
  instance=overwrite
  partial=nocheck
  runlevel=nocheck
  idepend=nocheck
  rdepend=nocheck
  space=ask
  setuid=nocheck
  conflict=nocheck
  action=nocheck
  basedir=default
  DONT_ASK
  /usr/sbin/pkgadd -a ${ADMIN_FILE} -d ${MNT} -R ${BASE} SUNWxyz
  umount ${MNT}
  rmdir ${MNT}
The following describes some commands for this example.
Example 4–4 Adding Patches With a Finish Script
 #!/bin/sh
# USER-CONFIGURABLE OPTIONS
# The location of the patches to add to the system after it's installed.
# The OS rev (5.x) and the architecture (`mach`) will be added to the
# root.  For example, /foo on a 8 SPARC would turn into /foo/5.8/sparc
LUPATCHHOST=ins3525-svr
LUPATCHPATHROOT=/export/solaris/patchdb
# NO USER-SERVICEABLE PARTS PAST THIS POINT
BASEDIR=/a
# Figure out the source and target OS versions
echo Determining OS revisions...
SRCREV=`uname -r`
echo Source $SRCREV
LUPATCHPATH=$LUPATCHPATHROOT/$SRCREV/`mach`
# Add the patches needed
echo Adding OS patches
mount $LUPATCHHOST:$LUPATCHPATH /mnt >/dev/null 2>&1
if [ $? = 0 ] ; then
	for patch in `cat /mnt/*Recommended/patch_order` ; do
		(cd /mnt/*Recommended/$patch ; echo yes | patchadd -u -d -R $BASEDIR .)
	done
	cd /tmp
	umount /mnt
else
	echo "No patches found"
if
Note –
In the past, the chroot(1M) command was used with the pkgadd and patchadd commands in the finish script environment. In rare instances, some packages or patches do not work with the -R option. You must create a dummy /etc/mnttab file in the /a root path before issuing the chroot command.
To create a dummy /etc/mnttab file, add the following line to your finish script:
cp /etc/mnttab /a/etc/mnttab
Customizing the Root Environment With a Finish Script
You can also use finish scripts to customize files that are already installed on a system. For example, the finish script in Example 4–5 customizes the root environment by appending information to the .cshrc file in the root (/) directory.
Example 4–5 Customizing the Root Environment With a Finish Script
#!/bin/sh
# Customize root's environment
echo "***adding customizations in /.cshrc"
test -f a/.cshrc || {
cat >> a/.cshrc <<EOF
set history=100 savehist=200 filec ignoreeof prompt="\$user@`uname -n`> "
alias cp cp -i
alias mv mv -i
alias rm rm -i
alias ls ls -FC
alias h history
alias c clear
unset autologout
EOF
Setting a System's Root Password With a Finish Script
After the Solaris software is installed on a system, the system reboots. Before the boot process is completed, the system prompts for the root password. Until someone types a password, the system cannot finish booting.
A finish script that is named set_root_pw is saved in the auto_install_sample directory. The finish script shows how to set the root password automatically, without prompting. set_root_pw is shown in Example 4–6.
Note –
If you set the system's root password with a finish script, users might attempt to discover the root password from the encrypted password in your finish script. Ensure that you safeguard against users who might try to determine the root password.
Example 4–6 Setting the System's Root Password With a Finish Script
	 #!/bin/sh
	 #       @(#)set_root_pw 1.4 93/12/23 SMI
	 # This is an example Bourne shell script to be run after installation.
	 # It sets the system's root password to the entry defined in PASSWD.
	 # The encrypted password is obtained from an existing root password entry
	 # in /etc/shadow from an installed machine.
	 echo "setting password for root"
	 # set the root password
 PASSWD=dKO5IBkSF42lw
	 #create a temporary input file
 cp /a/etc/shadow /a/etc/shadow.orig
	 mv /a/etc/shadow /a/etc/shadow.orig
 	nawk -F: '{
         if ( $1 == "root" )
           printf"%s:%s:%s:%s:%s:%s:%s:%s:%s\n",$1,passwd,$3,$4,$5,$6,$7,$8,$9
      else
		        printf"%s:%s:%s:%s:%s:%s:%s:%s:%s\n",$1,$2,$3,$4,$5,$6,$7,$8,$9
      }' passwd="$PASSWD" /a/etc/shadow.orig > /a/etc/shadow
 #remove the temporary file
 rm -f /a/etc/shadow.orig
 # set the flag so sysidroot won't prompt for the root password
 sed -e 's/0 # root/1 # root/' ${SI_SYS_STATE} > /tmp/state.$$
  mv /tmp/state.$$ ${SI_SYS_STATE}
The following describes some of the commands in this example.
Non-Interactive Installations With Finish Scripts
You can use finish scripts to install additional software after the Solaris OS is installed. The Solaris installation program prompts you to enter information during the installation. To maintain a hands-off installation, you can run the Solaris installation program with the -nodisplay or -noconsole options.
Table 4–1 Solaris Installation Options
Option
Description
-nodisplay
Runs the installer without a graphic user interface. Use the default product installation unless the installation was modified by the -locales option.
-noconsole
Runs the installation without any interactive text console device. Useful when paired with -nodisplay for UNIX script use.
For more information, see the man page installer(1M).
