Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations
x86: Disk Configuration File Example
The following example shows how to create a single-disk configuration file, 500_test, on an x86 based system that contains a 500-Mbyte disk.
Example 4–9 x86: Creating a Disk Configuration File
First, you save the output of the fdisk command to a file that is named 500_test:
# fdisk -R -W 500_test -h /dev/rdsk/c0t0d0p0
The 500_test file looks like the following:
 * /dev/rdsk/c0t0d0p0 default fdisk table
* Dimensions:
*     512 bytes/sector
*      94 sectors/track
*      15 tracks/cylinder
*    1455 cylinders
*  HBA Dimensions:
*     512 bytes/sector
*      94 sectors/track
*    1455 cylinders
* systid:
*  1:    DOSOS12
*  2:    PCIXOS
*  4:    DOSOS16
*  5:    EXTDOS
*  6:    DOSBIG
*  86:   DOSDATA
*  98:   OTHEROS
*  99:   UNIXOS
* 130:   SUNIXOS
* Id  Act Bhead Bsect   Bcyl  Ehead  Esect  Ecyl Rsect  Numsect
 130  128 44    3       0     46    30     1001 1410   2050140
Second, you append the output of the prtvtoc command to the 500_test file:
# prtvtoc /dev/rdsk/c0t0d0s2 >>500_test
The 500_test file is now a complete disk configuration file:
* Dimensions:
*     512 bytes/sector
*      94 sectors/track
*    1455 cylinders
*  HBA Dimensions:
*     512 bytes/sector
*      94 sectors/track
*    1455 cylinders
* systid:
*  1:    DOSOS12
*  2:    PCIXOS
*  4:    DOSOS16
*  5:    EXTDOS
*  6:    DOSBIG
*  86:   DOSDATA
*  98:   OTHEROS
*  99:   UNIXOS
*  130:  SUNIXOS
* Id  Act Bhead Bsect Bcyl  Ehead  Esec  Ecyl Rsect  Numsect
* /dev/rdsk/c0t0d0s2 partition map
* Dimensions:
*      512 bytes/sector
*       94 sectors/track
*     1110 sectors/cylinder
*     1454 cylinders
*     1452 accessible cylinders
* Flags:
*   1: unmountable
*  10: read-only
*                          First    Sector    Last
* Partition  Tag  Flags    Sector     Count    Sector  Mount Directory
       2      5    01       1410   2045910   2047319
       7      6    00       4230   2043090   2047319  /space
       8      1    01          0      1410     1409
       9      9    01       1410      2820     422987
You have created disk configuration files for an x86 based system. Testing a Profile contains information about using disk configuration files to test profiles.
