Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations
ProcedureTo Create a Temporary Solaris Environment to Test a Profile
To test a profile for a particular Solaris release successfully and accurately, you must test a profile within the Solaris environment of the same release. For example, if you want to test a Solaris initial installation profile, run the pfinstall command on a system that is running the Solaris OS.
You need to create a temporary installation environment if you are testing a profile under one of the following conditions:
  1. Boot a system from an image of one of the following:
    For SPARC based systems:
    • Solaris Operating System for SPARC Platforms DVD
    • Solaris Software for SPARC Platforms - 1 CD
    For x86 based systems:
    • Solaris Operating System for x86 Platforms DVD
    • Solaris Software for x86 Platforms - 1 CD
    Note –
    If you want to test an upgrade profile, boot the system that you are upgrading.
  2. Respond to the system identification questions.
  3. To exit from the installation program, type ! at the following prompt.
    The Solaris installation program  will assist you in installing software for Solaris.
    <Press ENTER to continue> {"!" exits}
  4. Execute the pfinstall command from the shell. For details about using the pfinstall command, see Step 7 in To Test a Profile.
