Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations
Packages Stored on an NFS Server
If the package is stored on an NFS server, use one of the following syntaxes for the package keyword.
package package_name add nfs server_name:/path [retry n]
package package_name add nfs://server_name:/path [retry n]
package_name
Specifies the package name in the form SUNWname. To view detailed information about packages and their names, on an installed system, use the pkginfo -l command.
server_name
Specifies the name of the server where you stored the package.
path
Specifies the location of the package directory on the specified server. If the path contains $HOST, $HOST is replaced with the name of the host system that you are installing.
retry n
Is an optional keyword. n is the maximum number of times the installation process attempts to mount the directory.
Example 8–12 Adding a Package by Using NFS
In this example, the package profile keyword adds the SUNWnew package from the NFS location nfs://golden/packages/Solaris_10/. If a mount fails, the NFS mount is tried five times.
package SUNWnew add nfs golden:/packages/Solaris_10 retry 5
