Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations
install_type Profile Keyword
install_type initial_upgrade_flash_switch
install_type defines whether to erase and install a new Solaris OS on a system, upgrade the existing Solaris OS on a system, or install a Solaris Flash archive on the system.
Note –
You must specify install_type in a profile, and install_type must be the first profile keyword in every profile.
You must use one of the following options for the initial_upgrade_flash_switch:
initial_install
Specifies to perform an initial installation of the Solaris OS
upgrade
Specifies to perform an upgrade of the Solaris OS
flash_install
Specifies to install a Solaris Flash archive that overwrites all files
flash_update
Specifies to install a Solaris Flash differential archive that overwrites only the files that are specified
Note –
Some profile keywords can only be used with the initial_install option. Some profile keywords can only be used with the upgrade option. Some profile keywords can only be used with the flash_install option.
