Solaris 10 11/06 Installation Guide: Solaris Flash Archives (Creation and Installation)
Keywords for the Archive Identification Section
The following tables describe the keywords for use in the archive identification section and the values you can define for them.
Every section uses the keywords in Table 5–3 to delimit each section.
Table 5–3 Archive Identification Section Keywords: General Keywords
Keywords
Value Definitions
Value
Required
section_begin
section_end
These keywords are used to delimit sections in the archive and are not limited exclusively to the archive identification section. For a description of these keywords, see General Keywords.
Text
Yes
The following keywords, used in the archive-identification section, describe the contents of the archive files section.
Table 5–4 Archive Identification Section Keywords: Contents of Archive Files Section
Keywords
Value Definitions
Value
Required
archive_id (optional)
This keyword uniquely describes the contents of the archive. This value is used by the installation software only to validate the contents of the archive during archive installation. If the keyword is not present, no integrity check is performed.
For example, the archive_id keyword might be FlAsH-ARcHive-2.0.
Text
No
files_archived_method
This keyword describes the archive method that is used in the files section.
  • If this keyword is not present, the files section is assumed to be in cpio format with ASCII headers. This format is the cpio -c option.
  • If this keyword is present, it has one of the following values:
    • cpio – The archive format in the files section is cpio with ASCII headers.
    • pax – The archive format in the files section is pax with extended tar interchange format. The pax utility enables archiving and extracting files that are greater than 4 GB.
If the files_compressed_method is present, the compression method is applied to the archive file that is created by the archive method.
Text
No
files_archived_size
This keyword value is the size of the archived files section in bytes.
Numeric
No
files_compress_method
This keyword describes the compression algorithm that is used on the files section.
  • If the keyword is present, it can have one of the following values.
    • none – The archive file section is not compressed.
    • compress – The file section is compressed by using the compress command.
  • If this keyword is not present, the archive files section is assumed to be uncompressed.
The compression method that is indicated by this keyword is applied to the archive file created by the archive method indicated by the files_archived_method keyword.
Text
No
files_unarchived_size
This keyword defines the cumulative size in bytes of the extracted archive. The value is used for file-system size verification.
Numeric
No
The following keywords provide descriptive information about the entire archive. These keywords are generally used to assist you in archive selection and to aid in archive management. These keywords are all optional and are used to help you to distinguish between individual archives. You use options for the flarcreate command to include these keywords. For details, see Example 3–9.
Table 5–5 Archive Identification Section Keywords: User Describes the Archive
Keywords
Value Definitions
Value
Required
creation_date
This keyword value is a textual timestamp that represents the time that you created the archive.
  • You can use the flarcreate command with the -i option to create the date.
  • If you do not specify a creation date with the flarcreate command, the default date is set in Greenwich mean time (GMT).
  • The value must be in ISO-8601 complete basic calendar format without the time designator (ISO-8601,§5.4.1(a)). The format is CCYYMMDDhhmmss. For example, 20000131221409 represents January 31, 2000, 10:14:09 p.m.
Text
No
creation_master
This keyword value is the name of the master system you used to create the archive. You can use the flarcreate -m option to create this value. If you do not specify a value, the value is taken from the uname -n command.
Text
No
content_name
This keyword identifies the archive. The value is generated from the flarcreate -n option. Follow these guidelines when you create this value:
  • The descriptive name can be no longer than 256 characters.
  • The description should contain the function and purpose of the archive.
Text
Yes
content_type
This keyword value specifies a category for the archive. You use the flarcreate -T option to generate the value.
Text
No
content_description
The keyword value describes the contents of the archive. The value of this keyword has no length limit. You use the flarcreate -E option to create this value.
Text
No
content_author
This keyword value identifies the creator of the archive. You use the flarcreate-a option to create this value. Suggested values include the full name of the creator and the creator's email address.
Text
No
content_architectures
This keyword value is a comma-separated list of the kernel architectures that the archive supports.
  • If the keyword is present, the installation software validates the kernel architecture of the clone system against the list of architectures that the archive supports. The installation fails if the archive does not support the kernel architecture of the clone system.
  • If the keyword is not present, the installation software does not validate the architecture of the clone system.
Text list
No
The following keywords also describe the entire archive. By default, the values are filled in by uname when the flash archive is created. If you create a flash archive in which the root directory is not /, the archive software inserts the string UNKNOWN for the keywords. The exceptions are the creation_node, creation_release, and creation_os_name keywords.
Regardless of their sources, you cannot override the values of these keywords.
Table 5–6 Archive Identification Section Keywords: Software Describes the Archive
Keyword
Value
creation_node
The return from uname -n
creation_hardware_class
The return from uname -m
creation_platform
The return from uname -i
creation_processor
The return from uname -p
creation_release
The return from uname -r
creation_os_name
The return from uname -s
creation_os_version
The return from uname -v
