Solaris 10 11/06 Installation Guide: Solaris Flash Archives (Creation and Installation)
Customizing the Solaris Installation on the Master System
After you install the Solaris OS on the master system by using any of the Solaris installation methods, you can add or delete software and modify system configuration information as necessary. To customize the master system's software, you can do the following:
