编写设备驱动程序
转储处理
在系统出现故障或执行检查点操作时,dump(9E) 入口点会将部分虚拟地址空间直接复制到指定的设备。请参见 cpr(7)dump(9E) 手册页。dump(9E) 入口点必须在不使用中断的情况下能够执行该操作。
dump() 的参数如下所示:
dev
转储设备的设备编号
addr
开始转储的内核虚拟地址
blkno
设备上的第一个目标块
nblk
要转储的块数
示例 17–7 dump(9E) 例程
static int
xxdump(dev_t dev, caddr_t addr, daddr_t blkno, int nblk)
    struct xxstate     *xsp;
    struct buf         *bp;
    struct scsi_pkt    *pkt;
    int    rval;
    int    instance;
    instance = getminor(dev);
    xsp = ddi_get_soft_state(statep, instance);
    if (tgt->suspended) {
    (void) pm_raise_power(DEVINFO(tgt), 0, 1);
    bp = getrbuf(KM_NOSLEEP);
    if (bp == NULL) {
    return (EIO);
/* Calculate block number relative to partition. */
bp->b_un.b_addr = addr;
    bp->b_edev = dev;
    bp->b_bcount = nblk * DEV_BSIZE;
    bp->b_flags = B_WRITE | B_BUSY;
    bp->b_blkno = blkno;
    pkt = scsi_init_pkt(ROUTE(tgt), NULL, bp, CDB_GROUP1,
    sizeof (struct scsi_arq_status),
    sizeof (struct bst_pkt_private), 0, NULL_FUNC, NULL);
    if (pkt == NULL) {
    freerbuf(bp);
    return (EIO);
    (void) scsi_setup_cdb((union scsi_cdb *)pkt->pkt_cdbp,
        SCMD_WRITE_G1, blkno, nblk, 0);
     * While dumping in polled mode, other cmds might complete
     * and these should not be resubmitted. we set the
     * dumping flag here which prevents requeueing cmds.
    tgt->dumping = 1;
    rval = scsi_poll(pkt);
    tgt->dumping = 0;
    scsi_destroy_pkt(pkt);
    freerbuf(bp);
    if (rval != DDI_SUCCESS) {
    rval = EIO;
    return (rval);
