编写设备驱动程序
detach() 入口点(SCSI 目标驱动程序)
detach(9E) 入口点与 attach(9E) 是反向的入口点。detach() 必须释放在 attach() 中分配的所有资源。如果成功,则 detach 应调用 scsi_unprobe(9F)。以下示例给出了目标驱动程序的 detach() 例程。
示例 17–3 SCSI 目标驱动程序 detach(9E) 例程
static int
xxdetach(dev_info_t *dip, ddi_detach_cmd_t cmd)
    struct xxstate *xsp;
    switch (cmd) {
    case DDI_DETACH:
       * Normal detach(9E) operations, such as getting a
       * pointer to the state structure
      scsi_free_consistent_buf(xsp->rqsbuf);
      scsi_destroy_pkt(xsp->rqs);
      xsp->sdp->sd_private = (caddr_t)NULL;
      xsp->sdp->sd_sense = NULL;
      scsi_unprobe(xsp->sdp);
       * Remove minor nodes.
       * Free resources, such as the state structure and properties.
          return (DDI_SUCCESS);
    case DDI_SUSPEND:
      /* For information, see the "Directory Memory Access (DMA)" */
      /* chapter in this book. */
    default:
      return (DDI_FAILURE);
