系统管理指南:IP 服务
ipsecinit.conf 文件样例
Solaris 软件包含一个 IPsec 策略文件样例 ipsecinit.sample。您可以使用此文件作为模板来创建自己的 ipsecinit.conf 文件。ipsecinit.sample 文件包含以下示例:
# For example,
#	 {rport 23} ipsec {encr_algs des encr_auth_algs md5}
# will protect the telnet traffic originating from the host with ESP using
# DES and MD5. Also:
#	 {raddr 10.5.5.0/24} ipsec {auth_algs any}
# will protect traffic to or from the 10.5.5.0 subnet with AH
# using any available algorithm.
# To do basic filtering, a drop rule may be used. For example:
#	 {lport 23 dir in} drop {}
#	 {lport 23 dir out} drop {}
# will disallow any remote system from telnetting in.
# If you are using IPv6, it may be useful to bypass neighbor discovery
# to allow in.iked to work properly with on-link neighbors. To do that,
# add the following lines:
#        {ulp ipv6-icmp type 133-137 dir both } pass { }
# This will allow neighbor discovery to work normally.
