系统管理指南:名称和目录服务(DNS、NIS 和 LDAP)
nsswitch.conf 模板文件
随 Solaris 系统提供了四个可以适用于不同名称服务的转换器模块文件。每个文件都提供一组不同的缺省信息源。
下面列出了这四个模板文件:
将最符合要求的模板文件复制到 nsswitch.conf 配置文件中,然后根据需要修改该文件。
例如,要使用 LDAP 模板文件,可键入以下命令:
mymachine# cp /etc/nsswitch.ldap /etc/nsswitch.conf
缺省的转换器模板文件
下面列出了随 Solaris 产品提供的四个转换器文件。
实例 2–1 NIS+ 转换器文件模板: nsswitch.nisplus
# /etc/nsswitch.nisplus:
# An example file that could be copied over to /etc/nsswitch.conf;
# it uses NIS+ (NIS Version 3) in conjunction with files.
# "hosts:" and "services:" in this file are used only if the
# /etc/netconfig file has a "-" for nametoaddr_libs of "inet"
# transports.
# the following two lines obviate the "+" entry in /etc/passwd
# and /etc/group.
passwd: files nisplus
group: files nisplus
# consult /etc "files" only if nisplus is down.
hosts: nisplus [NOTFOUND=return] files
# Uncomment the following line, and comment out the above, to use
# both DNS and NIS+. You must also set up the /etc/resolv.conf
# file for DNS name server lookup. See resolv.conf(4).
# hosts: nisplus dns [NOTFOUND=return] files
services: nisplus [NOTFOUND=return] files
networks: nisplus [NOTFOUND=return] files
protocols: nisplus [NOTFOUND=return] files
rpc: nisplus [NOTFOUND=return] files
ethers: nisplus [NOTFOUND=return] files
netmasks: nisplus [NOTFOUND=return] files
bootparams: nisplus [NOTFOUND=return] files
publickey: nisplus
netgroup: nisplus
automount: files nisplus
aliases: files nisplus
sendmailvars: files nisplus
实例 2–2 NIS 转换器文件模板
# /etc/nsswitch.nis:
# it uses NIS (YP) in conjunction with files.
# transports.
# and /etc/group.
passwd: files nis
group: files nis
# consult /etc "files" only if nis is down.
hosts: nis [NOTFOUND=return] files
networks: nis [NOTFOUND=return] files
protocols: nis [NOTFOUND=return] files
rpc: nis [NOTFOUND=return] files
ethers: nis [NOTFOUND=return] files
netmasks: nis [NOTFOUND=return] files
bootparams: nis [NOTFOUND=return] files
publickey: nis [NOTFOUND=return] files
netgroup: nis
aliases: files nis
# for efficient getservbyname() avoid nis
services: files nis
sendmailvars: files
实例 2–3 文件转换器文件模板
# /etc/nsswitch.files:
# it does not use any naming service.
# transports.
passwd: files
group: files
hosts: files
networks: files
protocols: files
rpc: files
ethers: files
netmasks: files
bootparams: files
publickey: files
# At present there isn't a 'files' backend for netgroup;
# the system will figure it out pretty quickly, and will notuse
# netgroups at all.
netgroup: files
automount: files
aliases: files
services: files
sendmailvars: files
实例 2–4 LDAP 转换器文件模板
# /etc/nsswitch.ldap:
# An example file that could be copied over to /etc/nsswitch.conf; it
# uses LDAP in conjunction with files.
# /etc/netconfig file has a "-" for nametoaddr_libs of "inet" transports.
and /etc/group.
passwd:     files ldap
group:      files ldap
hosts:      ldap [NOTFOUND=return] files
networks:   ldap [NOTFOUND=return] files
protocols:  ldap [NOTFOUND=return] files
rpc:        ldap [NOTFOUND=return] files
ethers:     ldap [NOTFOUND=return] files
netmasks:   ldap [NOTFOUND=return] files
bootparams: ldap [NOTFOUND=return] files
publickey:  ldap [NOTFOUND=return] files
netgroup:   ldap
automount:  files ldap
aliases:    files ldap
# for efficient getservbyname() avoid ldap
services:   files ldap
sendmailvars:   files
nsswitch.conf 文件
随 Solaris 软件安装的缺省 nsswitch.conf 文件由安装过程中选择的名称服务确定。每一行都标识特定类型的网络信息(如主机、口令和组)以及信息源(如 NIS+ 表、NIS 映射、DNS 主机表或本地 /etc)。在选择某个名称服务时,会复制该服务的转换器模板文件以创建新的 nsswitch.conf 文件。例如,如果选择 NIS+,则会复制 nsswitch.nisplus 文件以创建新的 nsswitch.conf 文件。
Solaris 9 发行版软件会自动将 nsswitch.conf 文件与下列备用(模板)版本一起加载到每台计算机的 /etc 目录中。
这些备用模板文件中包含由 NIS+ 服务、NIS 服务、本地文件和 LDAP 使用的缺省转换器配置。系统没有为 DNS 提供缺省文件,但是可以编辑其中的任何文件以使用 DNS。在将 Solaris 软件首次安装到计算机上时,安装程序会选择计算机的缺省名称服务。在安装过程中,会将相应的模板文件复制到 /etc/nsswitch.conf 中。例如,对于使用 NIS+ 的客户机,会在安装过程中将 nsswitch.nisplus 复制到 nsswitch.conf 中。
如果网络连接到 Internet,而且用户必须使用 DNS 访问 Internet 主机,则必须启用 DNS 转发。
除非您拥有特殊的名称空间,否则复制到 nsswitch.conf 中的缺省模板文件应该能够满足正常的操作。
